Implementing USER FORTRAN in CFX Without Intel Compiler: Seeking Guidance |
December 14, 2023, 03:44 |
ChangDeok Shin
I am currently working with CFX and aim to write a USER FORTRAN routine that monitors specific variable values over iterations and adjusts the inlet pressure accordingly. However, I'm using Windows and cannot access the Intel fortran compiler in my current setup. Therefore, I need to utilize a different compiler for USER FORTRAN. I know that modifying the cfx5mkext file can change the default compiler options, but I'm facing difficulties in generating the dll file when executing commands. Can anyone provide assistance or advice on this matter?
December 14, 2023, 04:57 |
Rep Power: 143 |
If you do not use the recommended fortran compiler then you are likely to have problems.
If you do not want to purchase Intel fortran then move to CFX on Linux and you can use open source fortran compilers.
December 21, 2023, 08:36 |
Evelyn
Rep Power: 5 |
Hello, I have recently been trying to use user-defined Fortran in CFX Pre. Have you successfully compiled the cfx5mkext command? Are you willing to share relevant tutorials?
../externals/cgns/hdf5/H5public.h:63:10: fatal error: mpi.h: No such file or director | Mohsin1 | SU2 | 8 | November 25, 2023 03:46 |
CFX User Fortran caveats | HLo | CFX | 0 | May 19, 2016 04:35 |
User Fortran with CFX 14.5.7 on winnt_amd64 | HLo | CFX | 22 | December 13, 2015 08:26 |
fortran compiler with CFX | camiliar | CFX | 0 | November 29, 2013 02:12 |
Intel Fortran Compiler for Linux System | Huang | Main CFD Forum | 0 | September 28, 2006 03:35 |
