June 26, 2011, 18:00 |
Results of CFX Simulations
AyAhSof
Helo,
I've done simulations, usin' CFX, on rotor passages. In the results i have noticed negative pressure values. I know that negative velocity values means that the fluid particule is movin' in the opposite direction, but i dont understand the meanin' of negative presuure values. Also, in papers reserchers show countours containin' regions of negative pressure. NB: I'm speakin' about countour pressure values, not values of pressure difference witch can mean that the flow is in opposite direction. I'll be gratefull if somebody explaine to me this. Thanks. |
June 26, 2011, 18:35 |
turbomachinery velocity diagram in CFX
AyAhSof
Usin' CFX Simulations on compressor passages, I have difficulties understandin' the absolute velocity and the relative velocity knowin' that in my results i have countours of Cm; W; velocity; ... I know that C=W+u; when C absolute velocity W relative velocity u speed of rotor, but in CFX documentation, i have found somewhere (with figures) the decompostion of V to streamwise velocity; spanwise velocity; circumferential velocity or to axial velocity; radial velocity, circumferencial velocity and also to Blade to blade velocity ...etc. So is V absolute or relative velocity; or can we say that C= (that V)+u; and how can we obtain in resutls Cu velocity; Cr velocity; Wu velocity; Wm velocity; Wr velocity. Can somebody help me understandin' this, or tell me in what part exactly of CFX documentation can i found the details of that (maybe i didn't searche well in it). |
June 26, 2011, 21:19 |
Rep Power: 143 |
Pressure is measured relative to a reference pressure. A negative pressure simply means the pressure is less than the reference pressure. If the reference pressure is one atmosphere then a nagative pressure simply means a vacuum.
July 9, 2011, 06:15 |
meanin' of Negative pressure values
AyAhSof
Dear Ghorrocks,
Thank you so much for helpin' me understandin' negative pressure values. |
Effective compression of results files of CFX | famarcfd | ANSYS | 0 | March 24, 2011 04:16 |
CFX pressure in Simulations problem | nasdak | CFX | 1 | April 14, 2010 13:22 |
time averaged results as initial conditions in CFX | mike | CFX | 8 | May 7, 2007 14:54 |
Import results to CFX post | MatjazR | CFX | 1 | October 17, 2005 09:07 |
CFX cylinder or sphere benchmark results | Mel | CFX | 1 | August 8, 2005 18:47 |
