Timescale in Steady-state
Old   July 3, 2011, 23:38
Default Timescale in Steady-state
Kim, Chang gon
Kim CK is on a distinguished road
I got several steay-state simulation results.
Each simulation has totally same geometry and condisions,
but the results are different.
The only difference is "Iteration number" in solver.
Flow velocity and Heat flux are not different.
But Temperature map(conduction : fluid->soild domain) is different as iteration number increases.
So I guess the results depend on time..
It was steady-state so I'm confused.
Is the Iteration number related to time??
Kim CK is offline   Reply With Quote
Old   July 4, 2011, 02:33
Smile
mohammad
mohammad is on a distinguished road
Hi Kim;
Definitely. you must look at your RMS values as criteria for your stop, or even if the RMS are not less than 10-5 you can have( define for yourself) some local criteria about the convergence of your desired results and parameters.
you may gain good info in the help manual of the software.
I'm thinking also mesh density can have some mutual effects with timestep...
good luck
mohammad is offline   Reply With Quote
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Under-relaxation for steady state simulation in CFX Chander CFX 7 May 1, 2014 12:44
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
steady state, laminar vof_model Garima Chaudhary FLUENT 0 May 24, 2007 03:11
