Simulate a micro valve with fsi
Old   July 13, 2011, 04:52
Default Simulate a micro valve with fsi
Frank Weise
FrankW is on a distinguished road
i try to simulate a micro valve with cfx. My first results of a simple 2D design are bad, because the mesh is distorted on the flap tip at the gap. I have tested many settings at the Mesh Deformation->Mesh Stiffness and i get not really a good deformed mesh. How can get i a good deformed mesh? The goal is to simulate a 3D model of a valve and if does'nt work in 2D i thing there is no chance to get a good 3d model. Has anyone a idea to modify the Mesh Stiffness so that i get usable mesh.
regards
Frank
FrankW is offline   Reply With Quote
Old   July 13, 2011, 09:05
stumpy is on a distinguished road
Try the expert parameter 'meshdisp diffusion scheme = 3'
stumpy is offline   Reply With Quote
Old   July 13, 2011, 19:38
I would us a GGI to connect the two regions. Then the outer region does not move (or at least not much), and the inner thin region can deform without constraint of the outer region. This will be much easier than thrying to get mesh motion to work across both regions together.
Old   July 14, 2011, 02:45
Frank Weise
@stumpy The expert parameter does'nt work. I've seen no effect of this to the deformed mesh.
@glenn What do you mean with inner and outer region? Can you make a sketch. I've defined one subdomain under the flap without meshmotion.
Old   July 14, 2011, 07:56
How does this look?
Old   February 14, 2013, 03:21
Default FSI mesh trouble
u22
Anthony Nitski
u22 is on a distinguished road
Hello all!
I am trying 3d FSI simulation with CFX 14, it crashes cause negative element is formed (see pic.). Setting meshdisp diffusion scheme 3 not avoid that error... How to get fixed wall mesh to "slide" along Y direction (but Z must be fixed) and to follow Y displacement of mesh on "Moving wall" side?
u22 is offline   Reply With Quote
Old   February 14, 2013, 04:01
Split your fluid domain into 3 joined fluid domains like this, as shown by the orange lines:
Give the vertical line the same X displacement as the piston, and the horz one the same vertical displacement. Then your mesh will stay nice and orthogonal.
Old   February 18, 2013, 07:55
u22
Anthony Nitski
Thanks for the tip, Glenn!
I divided domain into 3 sub-domain. But I did not get how to give to points at stationary wall same displacement as moving wall for corresponding directions.
"Give the vertical line the same X displacement as the piston, and the horz one the same vertical displacement."
I have to use CEL ? Or set some specific conditions at subdomain or walls, like "mesh motions = unspecified"
Old   February 18, 2013, 16:21
On second thoughts this is trickier than I originally thought - I do not know how to specify one dimension but leave another dimension unspecified. I cannot see how to do that. But it would be nice if you could do that, it would make a number of motions simpler to specify. Sorry if I mislead you.
Valve simulation with spring - FSI? Help! farianka CFX 1 April 17, 2011 18:04
Simulation of air flow inside valve - FSI? Help! farianka Main CFD Forum 0 April 17, 2011 16:30
Ansys FSI and CFX (valve simulation) farianka ANSYS 0 April 17, 2011 16:20
How can i simulate a valve motion ???????? popi CFX 6 September 19, 2006 10:54
How to simulate valve with pressure BC? Luk FLUENT 8 June 20, 2006 08:06
