August 11, 2011, 12:00 |
Rarefied gas
Rep Power: 15 |
Hi!
I'm modelling a reentry vehicle in CFX and I'm working with low density gas. I'm facing a problem with overflow in all my simulations: there are few peaks of pressure near the geometry (a blunted body) and 3 steps later, the simulation crashs. I read somewhere that Navier-Stokes does not work anymore for these conditions. Does someone have experience with this kind of simulation? Thanks in advance |
August 11, 2011, 19:16 |
Rep Power: 143 |
CFX should work fine until the gas can no longer be considered a continuum or until the gas disassociates. But for rarefied gasses you will probably need to use a different EOS.
But to start off I would just use an ideal gas at the temperature and pressure you are using, and once that is working reliably I would swap to a more accurate EOS. |
August 11, 2011, 21:54 |
Rep Power: 15 |
Thank you for you answer Glenn.
Do you have any idea when the continuum equation fails? I'm working with density of 10^-5 kg/m3 and I was suposing that this value could be the reason that causes overflow. |
August 11, 2011, 22:00 |
Rep Power: 143 |
August 12, 2011, 17:20 |
Rep Power: 15 |
Thank you Glenn. I'm gonna check this.
August 15, 2011, 09:28 |
Rep Power: 15 |
Hi again!
My Knudsen number is about 0.004 (M=10 and Re=4000). My conditions are calculated based on air ideal gas. So the solver should work fine but in the fifth step, the solver always returns this error: Parallel run: Received message from slave ----------------------------------------- Slave partition : 3 Slave routine : ErrAction Master location : RCVBUF,MSGTAG=1012 Message label : 001100279 Message follows below - : +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Floating point exception: Overflow Any idea? Thank you! |
August 15, 2011, 18:57 |
Rep Power: 143 |
Your Knudsen number looks OK, so CFX should be good to model this.
You are diverging numerically. Need to improve stability - smaller timesteps, double precision numerics, better mesh quality, better initial condition. |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
Rarefied Gas Dynamics | Andrea Panizza | Main CFD Forum | 3 | July 15, 2003 07:45 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
