August 24, 2011, 09:09 |
Time changing boundary condition
Hello guys
I have to run a transient simulation in which one of the boundary is radiation source and the radiation intensity id time dependent, its something like this.. Time from to radiation 09:00 10:00 40 Wm-2 10:00 11:00 180 Wm-2 11:00 12:00 350Wm-2 12:00 13:00 340 Wm-2 13:00 14:00 370 Wm-2 14:00 15:00 290 Wm-2 15:00 16:00 400 Wm-2 16:00 17:00 390 Wm-2 17:00 18:00 250 Wm-2 18:00 19:00 70 Wm-2 i created a function "Rad" with argument as time (mins) and value as radiation... somewhat like: 2 40 62 180 122 350 and so on.... and then a expression called "Radiation" with value "Rad(Time Step)" the transient simulation has to runs for 10 hr time period with 4 min time step. im not sure if i have done it correctly..... can anyone tell me is it correct, nad if not then please advise |
August 24, 2011, 18:43 |
Rep Power: 143 |
Sounds OK. Or you can skip the Radiation expression bit and make the radiation condition at the boundary simply defined as rad(t).
Not sure about your definition of Rad(Tiem Step) - shouldn't this be Rad(t), that is of time? |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Resolved: Changing boundary condition with UDF according to pressure outlet boundary | alpemre | Fluent UDF and Scheme Programming | 12 | February 24, 2014 10:18 |
External Radiation Boundary Condition (Two sided wall), Grid Interface | CFD XUE | FLUENT | 0 | July 8, 2010 06:49 |
vorticity boundary condition | bearcharge | Main CFD Forum | 0 | May 14, 2010 11:32 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
