October 29, 2010, 02:50 |
Porous loss model coefficient query
Stuart
Rep Power: 25 |
The two Momentum Source loss models (isotropic and directional) shown in the CFX Theory Guide (eqs. 1.146 and 1.149) show that the loss coefficient is multiplied by density / 2. When comparing these equations with the Dupuit-Forchheimer equation (http://en.wikipedia.org/wiki/Darcy's...non-Darcy_flow) the loss coefficient there (Greek letter beta) is multiplied only by density. I have dervied my loss coefficient from experimental data as like in the Dupuit-Forchheimer equation. So I just want to check if I should really be doubling this value in CFX-Pre so that CFX halves it as shown in the Theory Guide. I'm not sure why CFX uses the 1 / 2. But I've only found reference to the Dupuit-Forchheimer equation in wiki and no actual fluids textbooks. Thanks. |
October 29, 2010, 07:02 |
Rep Power: 143 |
I don't know the answer to your question, but I know what I would do if I needed to know.
I would set up a simple simulation with a block of porous material and simulate a known flow velocity across it to get a pressure drop. I would then work out the analytical pressure drop and make sure that the loss coefficient I put in was generating the pressure drop expected. It is always better to work these things out for yourself anyway. |
August 23, 2011, 00:58 |
Hamed
Rep Power: 15 |
If I don't the value for linear ressistance coefficient, can I not input any value? just select thethe isotropic loss to linear and quadratic resistance coefficients but then don't tick the box for entering a value. Is this ok?
thanks |
August 23, 2011, 06:38 |
Rep Power: 143 |
What are you trying to do?
August 24, 2011, 00:34 |
Hamed
Rep Power: 15 |
I am modeling a sloshing tank with mesh motion. Now I want to put in cylindrical baffel inside the tank which want to be 50% porous. I set it as isotropic loss but I dont know the linear and quadratic resistance coefficients. Can I not tick the linear and quadratic resistance coefficients options so I dont have to enter the value for it?
Another problem that i have faced is that in the porous setting I cant define mesh motion, but i simulate sloshing by mesh motion so what should i do? thx |
August 24, 2011, 06:21 |
Rep Power: 143 |
I am not sure you can have a porous region with mesh motion. If this cannot be done then you should impose the porous region yourself as a momentum source term.
August 24, 2011, 06:51 |
Hamed
Rep Power: 15 |
thx. can you tell me how should I impose the porous region as momentum source? how is this done? what do i need to do?
thx a lot. |
August 24, 2011, 07:41 |
Rep Power: 143 |
Determine the equation of your porous region (ie pressure drop versus velocity) and impose that as a momentum source. This is discussed in the documentation. You will probably need to include the source term linearisation term - again, see the doco.
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 07:18 |
drag coefficient computation on a porous jump??? | Fabrice | FLUENT | 4 | June 5, 2017 05:30 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
porous medium model, help please! | cloudnqh | FLUENT | 0 | February 26, 2010 14:27 |
about compresive phase | James | CFX | 10 | September 12, 2006 03:16 |
