Non uniform pressure ansys in CFX.
Old   August 26, 2011, 03:33
Default Non uniform pressure ansys in CFX.
sivaji is on a distinguished road
Dear All,
I was completed NACA rotor ansys with uniform pressure at inlet in CFX.I got results, which were almost matched with experimental data. Now i want to do same ansys with non uniform pressure at inlet. If anyone of us know about this process plz share with me and guide me for getting best results.my mailing address is sivajiganesh9@gmail.com. thank you for spending your valuable time.
sivaji is offline   Reply With Quote
Old   August 26, 2011, 04:52
Originally Posted by sivaji View Post
Dear All,
Dear All,
Old   August 26, 2011, 06:37
What type of pressure distribution do you want to apply?
Old   August 26, 2011, 06:45
Thanq for responding sir, The profile is varied along the radius from Hub to shroud (i.e. i want to take more points near hub and casing and). Its looks curvature at hub & shroud.
Old   August 26, 2011, 07:02
If you have an expression as a function of position then you can either define a CEL expression or use a 1D or 3D interpolation function.
Old   August 26, 2011, 07:13
I dnt have any expression as a function of position, in CFX help file i read as by importing of .CSV file for running this case. I had assumed some points (Pressure values) at hub and casing BCZ i know the Static Pressure range, by plotting graph the Pressure Vs Radius its given curvature which was similar to what i want.But its not running properly after few iterations solutions stops.
Old   August 26, 2011, 22:12
So is your problem that you cannot implement the varying pressure boundary, or that your model does not converge?
Old   August 27, 2011, 00:18
The profile is loading normally but its not creating any results file (i.e. .res file)
Old   August 29, 2011, 05:36
Dear Glenn, the inlet pressure profile is loading normally but its not creating any results file (i.e. .res file). I stuked with this case.
Old   August 29, 2011, 18:42
If it does not produce a res file then either:
1) You told it not to.
2) The solver crashed
3) The solver had a problem reassembling the final results, this sometimes happens in parallel runs.
If it is 1) then well, you can sort that one out.
If it is 2 or 3 then you will need to post the output file (as an attachment) on the forum for us to help you.
Free jet simulation msarkar OpenFOAM Running, Solving & CFD 39 May 11, 2021 13:21
Compressible Flow in Ansys CFX bcheruk CFX 15 July 6, 2017 06:30
about reference pressure in CFX adam2008 CFX 0 May 14, 2011 22:14
Exporting results from CFX to ANSYS ?? sohail ahmed CFX 1 December 20, 2007 01:10
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
