Turbomachinery - change rotation every 30 timesteps (CEL)
Old   September 2, 2011, 13:51
Question Turbomachinery - change rotation every 30 timesteps (CEL)
lindner is on a distinguished road
The title gives a hint, i need to change the rotation of my machine every 30 timesteps, increasing in 10 rpm.
Example: Iteration 1 angular velocity = 120
Iteration 30 angular velocity = 120+10
Iteration 60 angular velocity = 120+10+10
I tought something like this
if(citern=30, AngVel=AngVel+10)
if(citern=60, AngVel=AngVel+10) ...
I never programmed in CEL, so i don't know all the options to script that.
Anyone have an ideia to make this as simple as possible?
Thanks in advance
lindner is offline   Reply With Quote
Old   September 2, 2011, 18:36
You could write this function using the mod function in CEL, or you could define a 1D interpolation function.
Old   September 6, 2011, 07:03
Thanks ghorrocks, i will try this mod function and post the results later.
Old   September 6, 2011, 08:27
ok, now my rotation speed increases every 30 iterations, see above.
rot = 120 [rev min^-1]
rotVar = rot + r1*yy+r2*yy+r3*yy
r1 = if(citern>=30,1,0)
r2 = if(citern>=60,1,0)
r3 = if(citern>=90,1,0)
yy = 10 [rev min^-1]
Is it possible to make the variable dependent on the RMS residuals instead of iterations? Like if (RMS<0.0001,1,0)
What should be in the place of RMS variable?
thanks
Old   September 6, 2011, 18:56
I don't think the RMS residuals are a CEL variable, so I don't think you have access to it.
turbine cel timestep
UDF to change Rotation Speed in a MRF simulation Mike FLUENT 3 September 27, 2011 06:46
setting CEL dependent on change of volumeInt() Daiga CFX 4 April 5, 2007 11:56
Relief Plots in CFX Michael CFX 15 June 30, 2006 08:01
no enthalpy change across the momentum source Atit Koonsrisuk CFX 2 December 19, 2005 02:33
