September 12, 2011, 10:52 |
density current-outlet boundary condition
Rep Power: 16 |
I want to simulate an open-channel flow that at the begining of my experience has only water and air. The experience begins with the injection of a mixture of water and sediments into this channel. I have a device that allows the water height to remains constant. I would like to know your opinion about:
-As i am not interested in modeling the air part i am modeling the free surface with a free slip boundary condition. Agree? -At the outlet boundary condition i am using the option average static pressure, with relative pressure=0 and the pressure profile blend=0.05 (average over whole outlet). Agree? Best Regards |
September 12, 2011, 19:59 |
#2 | ||
Rep Power: 143 |
September 13, 2011, 05:22 |
Rep Power: 16 |
Hi Glenn.
In what relates my top boundary condition i will try to check your suggestion. CFX is computing a recirculation zone in the top of my domain that was not supposed to be there and I want to check if itīs possible to improve my results in this zone. In what concerns my outlet boundary condition, in my experimental setup, I have initially an hydrostatic pressure distribution in the outlet (just clean water) but then, when I inject the mixture (water+sediments) the pressure distribution ceases to be hydrostatic...Also the sediments and the water that left the domain are captured by a feedback circuit. I have choosen the option average static pressure, with relative pressure=0 and the pressure profile blend=0.05 (average over whole outlet) because it seemed to be the most appropriate for me. |
September 13, 2011, 10:11 |
Rep Power: 16 |
Do you consider this is the best way of modeling the outlet ? I am having some difficulties with my results so I need to check all details. Thanks.
Regards. |
September 15, 2011, 07:10 |
Rep Power: 16 |
Glenn, in what concerns the top boundary condition, you were referring to a condition of "opening" type?Such as in the free surface over a bump tutorial?
September 15, 2011, 19:05 |
Rep Power: 143 |
Yes, an opening.
If you are having troubles with your outlet boundary then move it further downstream. |
September 22, 2011, 10:09 |
Rep Power: 16 |
Glenn, but if I put an opening boundary condition it may happen that the fluid goes out of my domain...and in my experience the water level remains constant.Furthermore it could be even harder to get convergence. Do you agree with my comment?
I have tried to implement a symmetry boundary at the top of the domain but i have received a very strange error. |
September 22, 2011, 10:24 |
Rep Power: 16 |
Also, do you think that a no-slip wall will be an option for my top boundary condition. As i have said I am having negative velocities at the top of my domain that should be approximately = zero(at the moment i am using a free slip wall)
September 22, 2011, 18:23 |
#9 | |
Rep Power: 143 |
The alternative (a free slip boundary) means that the pressure will vary along the interface. If you want to use the single phase approximation you then need to choose whether the correct pressure but small flow across the interface (ie the pressure approach) or the wrong pressure but no flow across the interface (ie the free slip boundary approach) is best. |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
External Radiation Boundary Condition (Two sided wall), Grid Interface | CFD XUE | FLUENT | 0 | July 8, 2010 06:49 |
VOF Outlet boundary condition in cfd - ace | JM | Main CFD Forum | 0 | December 15, 2006 08:07 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
Outlet velocity boundary condition | Jay | FLUENT | 4 | December 15, 2002 08:27 |
