Modeling of water infiltration into a tank containing a permeable soil |
September 13, 2011, 04:32 |
idir
Rep Power: 15 |
Hello all
I need to model the infiltration of water into a tank containing a permeable soil during a time t. For this I referred to tutorials (Chapter*9:*Free Surface Flow Over a Bump) and (Chapter*12:*Flow in a Catalytic Converter) to do the modeling (see attachment 1 to 10 ): *Analysis type : Transient. *2 domains: 1-->Water_and_Airas in tuto9:free surface flow) 2-->SoilPorous domain as in tuto 12) but the results obtained are not normal (incorect) (see attachment 11to 14) . Please send your views and advice about the boundary conditions and Domains so on. Thank you in advance. |
September 13, 2011, 04:34 |
idir
Rep Power: 15 |
following of the attachment
September 13, 2011, 04:37 |
idir
Rep Power: 15 |
and the results of this simulation
September 13, 2011, 08:15 |
Rep Power: 143 |
What is incorrect about the results?
September 13, 2011, 09:14 |
idir
Rep Power: 15 |
Hi
The problemes are: 1- the water level above land does not decrease over time 2- and when I change the properties of the soil making it more permeable (volume porosity and permeability of 0.9 to 0.2) I find very different results (see photos1 to 5) and her also the water level does not decrease Last edited by idir; September 13, 2011 at 09:33. |
September 13, 2011, 19:22 |
Rep Power: 143 |
1 - How are your imbalances? If the Volume fraction variable has a small imbalance then it is being conserved and the top surface should be moving properly. If not then you need to converge tighter.
2 - You have a fluid region above an air region which you suddenly release. In the absence of the porous region this would result in a chaotic mixing and splashing behaviour - this looks very similar to what you are getting. Are you sure your porousity is high enough to get the effects you are looking for? Also as you do not have a sharply defined free surface, have you turned on the free surface model? Are your time steps fine enough to resolve the motion? Do you have the correct volume fraction differencing scheme (compressive is the one you want here)? |
September 14, 2011, 06:03 |
#7 | ||
idir
Rep Power: 15 |
Thank you for your answer
But In this simulation i set the initialization of: Water domain: Water VolumFraction = 1.0 /AirVolumFraction = 0.0 and SoilPorous domain: Water VFraction = 0.0 / AirVFraction= 1.0 and I do not know if it's good or not? Quote:
Thank you in advance ghorrocks. |
September 16, 2011, 06:07 |
idir
Rep Power: 15 |
Now it's ok it works, you have just to turn on free surface option in Solver
thank you |
September 16, 2011, 06:40 |
#9 | |||
Rep Power: 143 |
Filling Tank with Water | leff | CFX | 7 | August 21, 2017 07:47 |
Simple Water Tank Transient | 88phil88 | CFX | 5 | March 17, 2014 03:48 |
Water Evaporation and condensation modeling | Linjie | FLUENT | 3 | February 6, 2012 13:08 |
modeling spilling of water from a tank | jemteo | CFX | 6 | June 25, 2006 19:33 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 07:10 |
