Stall in axial compressor
Old   September 28, 2011, 09:21
Default Stall in axial compressor
mistry
csmistry is on a distinguished road
Dear sir,
what will be the best way to predict stalling mass flow rate?
While doing simulation at low mass flow rate convergence is a issue and even expert parameter say total pressure also fluctuates!!!
Guide me for the same.
csmistry is offline   Reply With Quote
Old   September 28, 2011, 14:19
Far
Sijal
your last stable operating point is the your stall point, afterwards surge/rotating stall is begin to occur. Mostly this approach is enough for the numerical studies as indicated by many researchers.
As you know that surge is unsteady phenomena, in which compressor goes into cycle of low mass flow rate, low pressure ratio and then again high mass flow rate and high pressure ratio and this cycle repeats forever, unless some method applied to get rid of surge. This is also know as hysteric loop and is highly unsteady, therefore you need to use the unsteady RANS.
Old   September 28, 2011, 23:35
mistry
Dear sir,
This phenomena is known but the question is how to capture it in Computational analysis for different mass flow study.
Old   September 29, 2011, 08:10
Far
Sijal
do you want to say that " you want to simulate the post stall scenario?" or "you want to determine the stall point numerically"
Old   September 29, 2011, 23:41
mistry
Sir, both the things....
Old   August 13, 2012, 16:51
Mary
maryamprana is on a distinguished road
I found my question here, but unfortunately not the answer. Does anyone know the answer? "How to determine the stall point numerically?"
maryamprana is offline   Reply With Quote
Old   October 31, 2012, 06:16
vicarious's Avatar
Pedram Mojtabavi
vicarious is on a distinguished road
Send a message via Yahoo to vicarious
According to references (even recent ones), the prediction of rotating stall phenomena cannot be determined accurately by numerical simulations. But there is a point in compressor map that is the last stable performance of the compressor. At mass flow rates lower than this point, the compressor parameters, for example mass flow rates, starts to oscillate during unsteady simulation. The oscillation starts with a high amplitude part-span stall. if the oscillation's amplitude gets low, it means a full-span stall has occurred and the compressor is working under unstable region. Different values of the compressor's flow and head coefficients have to get extracted and simulated so you can determine the stall point.
vicarious is offline   Reply With Quote
Axial compressor bleed modelling Kishore Main CFD Forum 1 May 28, 2014 20:00
Axial Compressor experts needed.... arunraj CFX 5 August 17, 2011 19:21
Multi-stage axial flow compressor CAD model aeroranger Main CFD Forum 1 October 1, 2009 06:52
Fluent Analysis Of Axial Compressor Puneet Jindal FLUENT 0 June 25, 2009 17:33
boundary conditions - axial compressor Ramesh.K FLUENT 0 April 6, 2007 21:55
