October 5, 2011, 04:09 |
Error
oscar
I have a problem with my simulation. It suddenly stops with the typical problem of overflow but in .OUT file there's omething else which says: "A wall has been placed at portion(s) of an OUTLET boundary condition (at 100.0% of the faces, 100.0% of the area) to prevent fluid from flowing into the domain. I don't really understand, I made my solver conditions as robust as possible, playing with the advection scheme and the time step but it does not really helps. Any idea? |
October 5, 2011, 06:35 |
Rep Power: 143 |
When a solution is diverging (ie the overflow comment) then anything can happen. So flow going backwards is quite possible as the results will be total rubbish.
October 5, 2011, 09:09 |
oscar
I know...I've read that in cavitation simulation, transient problems converge more easily than stationary ones. Is it true? May I consider to simulate a short physical time rather than wait for a stationary solution???
Thanks in advance! |
October 5, 2011, 18:46 |
Rep Power: 143 |
Yes, transient simulations are easier to converge that steady.
But it depends on what you want - if you want the steady state flow you will have to run the transient simulation a long time to get there. |
October 6, 2011, 03:40 |
oscar
Yes sure...thank you very much! I'll try then
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
c++ libraries and solver compiling | vaina74 | OpenFOAM Installation | 13 | February 3, 2012 17:43 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
