Is there a way to postpone the batch run for a while? |
October 11, 2011, 23:10 |
When I run a batch, the error message below comes out right after a normally finished one.
| ERROR #001100247 has occurred in subroutine . | | Message: | | | | The solver is unable to continue because of licensing problems. | | | | A license for the following capability level could not be checked | | out: | | | | Basic Capability Solver After searching the solution from this forum, someone said it may caused by the unfreed license. http://www.cfd-online.com/Forums/cfx...-problems.html So, I am wondering that is there a way to postpone the run for a while, 10 seconds for example, to let the license freed up, and then start the next model calculation normally? I setup the batch to include 15 models yesterday, found 3 of them which are not successive have been finished this morning, and the rest are interupted by the ERROR #001100247. Thanks for any suggestion from you. |
October 12, 2011, 06:50 |
Rep Power: 143 |
google it and you will find it.
In Windows the command is "pause 10", and you need to install a windows additional commands pack to access it - again google it to find it. |
October 14, 2011, 00:37 |
#3 | |
Thank you, Glenn. Pause does not work, since it need a manually operation to continue. I am trying the command of "ping localhost -n 10", if it works well, I will let you know. |
use batch mode to run an unsteady case | PaulineP | FLUENT | 9 | April 4, 2019 08:18 |
how to create input file to run fluent in batch | Aireen | FLUENT | 6 | November 21, 2016 08:27 |
batch run | N.R. | CFX | 1 | June 17, 2007 22:44 |
problem with running UDF in batch mode | James | FLUENT | 0 | June 6, 2006 06:49 |
Batch Run | Ogbeni | CFX | 4 | October 15, 2003 12:33 |
