October 12, 2011, 08:45 |
Access to arrays of Pressure matrix in CFX
omid
Rep Power: 14 |
Hi all
I'm trying to simulate flow over airfoil. this airfoil has a moving surface and the relation that specify mesh motion of this surface based on pressure distribution on surface. in this relation i need to access the arrays of pressure in this surface, such as pressure on a line on surface of airfoil. How can i do this? Thanks, best regards. |
October 12, 2011, 19:13 |
Rep Power: 143 |
Have a look at the rigid body motion example tutorials which come with CFX. You will need V13, it was not in previous versions.
October 13, 2011, 03:26 |
omid
Rep Power: 14 |
Thanks for reply of my question ghorrocks,
How does it work in ansys 13? |
October 13, 2011, 05:04 |
Rep Power: 143 |
As I said, have a look at the tutorials.
October 13, 2011, 18:16 |
omid
Rep Power: 14 |
I studied that, but i can't find any things useful for my case. i need use pressure with argument as Pressure(x,y,z). for example pressure on each node of a line or edge in inlet. How can i do this?
Best regards. |
October 14, 2011, 12:05 |
omid
Rep Power: 14 |
How can i specify an expression that do this: the pressure on 0<x<2 and 0<y<2 saved to an expression ?( Pressure on each node of one surface)
CFX pressure to structure - problem | nasdak | CFX | 2 | September 17, 2009 07:49 |
Pressure Rise Error | emueller | CFX | 0 | May 5, 2009 11:08 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
How to obtain correct viscous pressure drag using CFX? | Ketut Utama | Main CFD Forum | 1 | January 25, 1999 05:05 |
