November 30, 2011, 05:13 |
CFX-11 vs CFX-13 SST Model
Rep Power: 15 |
Hey,
I'm simulating a two-pass-channel with rectangular geometry. I've got some previous results with CFX-11 and SST Model. The previous simulation (done by a other person) compares different turbulence models for the same geometry. My CFX-13 results (also done with SST model) are different. So does anybody know, what ANSYS changed in there turbulence models? It kind of looks like the CFX-13 SST model uses some elements from CFX-11 SST cc model. Hope you guys know a little bit more. |
December 1, 2011, 16:48 |
Rep Power: 143 |
I suspect there have been some small changes in a few of the peripheral models (eg streamline curvature) and the numerics could be different. You would have to either troll through the release notes or contact CFX support to be sure.
December 1, 2011, 23:46 |
Rep Power: 143 |
For almost all cases you won't find a difference. It is only on rare cases that you will find a difference.
December 2, 2011, 02:18 |
Rep Power: 15 |
Thanks guys. I compared the factor in theory guide and there are all the same. I was just wondering about my results (compared to a old study done by a stundent in 2010)
December 2, 2011, 04:14 |
#9 |
Rep Power: 15 |
Not quite the same (I don't habe the old mesh). Problem is, that I am doing a conjugated calculation for a ribbed cooling-channel. The older thesis did only simulate the fluid with constant wall-temperature. My results are not very close to the experiment (different contour). The old thesis (turbulence model study) has almost the same contour with SST. But the old SST cc looks quite the same as my SST. And in the end my results for heat transfer are too good (Nu/Nu_0 is almost constantly 0.5 above experiment).
December 2, 2011, 04:33 |
#10 |
SST and SST-CC model are same except in some flow regions where CC model is activated (some triggering factor in production term). Therefore if your problem does not have that sort of region of flow then SST and SST-CC shall behave identically.
December 2, 2011, 04:40 |
#11 | |
Rep Power: 15 |
So I startet a SST-cc calculation, and then I'll see if there is a difference in CFX-13. |
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 07:18 |
[ICEM] Proper way to name boundaries on 2D model for use in CFX? | RossFS | ANSYS Meshing & Geometry | 4 | November 10, 2011 02:38 |
Missing Information in SST Transition Model Formulation | Josh | CFX | 2 | September 14, 2010 11:49 |
Turbulence model for CFX moving mesh | songxguan | CFX | 7 | June 28, 2009 21:05 |
Implementation details of SST k-omega model | Niels | Main CFD Forum | 3 | July 3, 2008 17:45 |
