Negative power and torque(Axial Turbine analysis)
Like Tree1Likes
Old   December 18, 2011, 12:10
Default Negative power and torque(Axial Turbine analysis)
mak86 is on a distinguished road
Dear all,
I have modeled an axial turbine in CFX. I used the macro calculator to get the torque and power and it gives me negative torque and power! What does it mean?
If a negative torque is just mentioning the direction of rotation so why should I get a negative power(since P=T.Omega)?
Thanks
mak86 is offline   Reply With Quote
Old   December 18, 2011, 16:43
It means you have not hit the steady state operating condition.
For instance, if you run a turbine at too high a rotational velocity you will get negative net torque - this means the rotor is running too fast and will decelerate. If you run it too slow it will generate positive torque and accelerate. The steady state operating point is where the net torque is zero.
ghorrocks is online now   Reply With Quote
Old   December 18, 2011, 17:05
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
What is the value of total pressure (stationary reference frame) at inlet and outlet? What type of boundary conditions you are applying at inlet and outlet.
Far is offline   Reply With Quote
Old   December 19, 2011, 02:00
Thank you both.
The rotor speed is -1000 rpm, the input BC is a mass flow of 250 kg/s and the output BC is static pressure of 1 atm.
The results are attached.
Old   December 19, 2011, 03:51
Far
Sijal
1. cant you apply the total pressure at inlet?
2. Why efficiency is more than 100%, it seems that either rotation direction is wrong (working as compressor) or solution is not converged.
3. Did you model the NGV before the rotor, if no how you are specifying the velocity components in axial and tangential dirction along with correct sign. (obviously r component is zero).
Old   December 19, 2011, 04:10
Far
Sijal
did you specify the correct rotation axis in macro calcular panel?
Old   December 19, 2011, 04:36
1.Unfortunately not.
2.I know that, the rotation direction is correct but the interesting point is that even changing it will not lead into a positive magnitude.
3.I have specified mass flow rate at inlet in turbo mode.
Yes
Old   December 19, 2011, 05:48
Your mesh looks very coarse. Have you read this FAQ: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
Especially the bit about mesh resolution?
Old   December 20, 2011, 01:10
@ghorrocks: I decreased the mesh size to 0.003 but no lock... it is still negative.
and the solver manager shows this for every step in the out file.
| ****** Notice ****** |
| A wall has been placed at portion(s) of an OUTLET |
| boundary condition (at 40.1% of the faces, 43.3% of the area) |
| to prevent fluid from flowing into the domain. |
| The boundary condition name is: R1 Outlet. |
| The fluid name is: Water. |
| If this situation persists, consider switching |
| to an Opening type boundary condition instead. |
The solver reaches an rms value of 1e-4 at about 50 steps.
Old   December 20, 2011, 04:00
Far
Sijal
1. decrease static pressure at oultet
2. From the Picture of your geomtry, why geomtry converged to single line on hub side, is this a design feature.
Old   December 20, 2011, 04:10
1.Static pressure is zero.
2. That is where hub ends.
Old   December 20, 2011, 04:38
Far
Sijal
can you please attach the ccl file?
Old   December 20, 2011, 05:09
Here it is.
Old   December 20, 2011, 05:36
Look a bit deeper. Graph the torque versus mesh size. Is it trending in the right direction? Is it all over the place? This can tell you if you are close or not.
You outlet is showing lots of back flow and the suggests your outlet is too close to the blades. You will need to extend your domain further downstream.
Old   December 20, 2011, 05:40
And please show some images of the flow field - steamlines would be nice.
Old   December 20, 2011, 06:49
Far
Sijal
I guess you are making some common/basic mistake in setting-up the problem in CFX. Are you clear that the rpm are -1000 or 1000. Could you please show some pics of CFX pre with axis visible.
What about reference pressure, is it also equal to 0?
Old   December 20, 2011, 09:03
nitheshkumble is on a distinguished road
by default in CFX pre if you give negetive speed(- sign) then rotor rotates anticlockwise.
find the enthalpy drop ,for turbine the enthalpy will reduce it from inlet to outlet.
nitheshkumble is offline   Reply With Quote
Old   December 20, 2011, 09:16
Far
Sijal
not necessary, it depends on the geometry and also whether it is turbine or compressor. Just take an example of twin spool turbofan engine.
Old   December 20, 2011, 14:33
First of all, thank you all.
Decreasing the mesh size did not influence the torque.
Extending the domain at downstream increased the backflow area to 90 percent.
Omega equals -1000rpm and as I said even changing it to 1000 did not influence the negative torque.
Old   December 20, 2011, 16:08
Sounds extremely unlikely. What meshes did you check?
Then you need to go further downstream.
