switching boundary conditions between wall and outflow |
February 9, 2012, 01:46 |
Rep Power: 14 |
Say I have modelled a simple Y-tube (consisting of one inlet and two outlets),I want to switch the boundary conditions between the two outlets to wall and outflow.I suppose this has to be done using CEL? If so how do I do the switching? |
February 9, 2012, 06:26 |
Rep Power: 143 |
You cannot do it in CEL. CEL (or CCL) cannot be used to change boundary condition types. You will have to run it through CFX-Pre again.
February 9, 2012, 10:02 |
Rep Power: 14 |
can you elaborate when you say ,you have to run it through CFX-pre again?say I designed the tube ,setup the mesh and defined already existing boundary conditions in setup ...Being a novice and a first timer I cant help but ask you again
February 9, 2012, 16:07 |
Rep Power: 143 |
You have to load it in pre and change the BC type there, and re-generate the def file.
CFX13 Post Periodic interface | EtaEta | CFX | 7 | December 8, 2011 17:15 |
outflow boundary conditions | DaIN | Main CFD Forum | 4 | May 12, 2011 14:32 |
Help with boundary conditions | Dan | CFX | 0 | April 3, 2006 11:32 |
Multiple outflow boundary conditions | Christian Redl | Main CFD Forum | 1 | April 14, 2000 11:51 |
