The object "ADDITIONAL VARIABLE: alfa" is present in the object "/FLOW:Flow Analysis |
September 17, 2012, 10:04 |
Problem at interface: an object is present but it is not physically valid
Rep Power: 13 |
Hello dears,
I'm doing a simulation with a part made of a porous domain with a solid phase and a fluid phase (resin), with an additional variable defined only inside the resin ("alfa", additional variable defined through a transport equation). The porous domain flows in a steel die: with this configuration all works fine. When I insert in the porous domain also a second fluid (air ideal gas), I have a warning that say me: "The object "ADDITIONAL VARIABLE: alfa" is present in the object "/FLOW:Flow Analysis 1/DOMAIN:Part/BOUNDARY: Default Solid Porous Interface Side 1/BOUNDARY CONDITIONS" but it is not physically valid. Substantially I have a problem at the die-part interface (at porous domain side). Opening the specified interface window, it isn't possible to delete alfa from the interface. How I can do? Last edited by l.te; October 7, 2012 at 05:17. |
October 7, 2012, 05:21 |
Rep Power: 13 |
Hello, anyone can help me?
Thanks |
October 7, 2012, 06:24 |
Rep Power: 143 |
I am not sure but I suspect you have to define your AV in all domains. I do not think it can only exist in one domain.
October 7, 2012, 06:36 |
#4 | |
Rep Power: 13 |
So I don't think it is a problem of domains, I think that could be a multiphase problem, because it only presents when I introduce the air... |
October 9, 2012, 13:56 |
#5 | |
Rep Power: 13 |
engineFoam with layers - pressure problems when adding layers | mturcios777 | OpenFOAM Running, Solving & CFD | 23 | January 4, 2023 21:56 |
[foam-extend.org] Error compiling OpenFOAM-1.6-ext | Canesin | OpenFOAM Installation | 137 | January 20, 2016 14:56 |
emag beta feature: charge density | charlotte | CFX | 4 | March 22, 2011 09:14 |
Compilation error OF1.5-dev on Suse10.3 | darenyang | OpenFOAM Installation | 0 | April 29, 2009 04:55 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
