phase change with CFX
Old   February 24, 2012, 00:45
Default phase change with CFX
K.M.Yang
aximefu is on a distinguished road
· I want to simulate the phase change in micro heat pipe with triangle cross section, and I set up a model. I made the configuration as follows:
1water and water vapor are continuous fluids, and they have the constant properties;
2Free surface model;
3heat transfer model: Thermal Energy, turbulence model: BSL Reynolds Stress;
4Surface Tension Coefficient is constant;
5Surface Tension Force: continuum Surface Force, Primary Fluid is water;
6Interphase Transfer: Free Surface ;
7Momentum Transfer: Drag Coefficient
8Mass Transfer: Phase change, phase change model is “Thermal Phase change” and a constant Saturation Temperature will be given;
9Heat Transfer: Two Resistant, vapor side set to be “zero thermal resistance”
Initial conditions: Velocity Type option is Automatic, the temperature set to be ambient temperature, the volume fraction of water is 0.75
Boundary conditions: Heat flux boundary is applied on the face of heat in and heat out, and adiabatic boundary condition is applied on the other surfaces. Wall contact angle is 101°.no slip wall is chosen for water and water vapor.
Results:
The simulation results are shown as follows:
The phenomena that liquid flows from the condenser to the evaporator in the sharp corners, while the vapour moves from the evaporator to the condenser in the centre of the micro heat pipe is not happened. The whole zone in heat pipe is full of water, that is not identical to the overall mass. And interphase mass transfer rate is too small almost close to zero.
So anyone have experience about simulation of phase change point me out the mistake I had made in my simulation? Thanks a lot!
aximefu is offline   Reply With Quote
Old   March 22, 2012, 01:12
Default HI
Danial
Danial Q is on a distinguished road
Did u solve that problem??
Danial Q is offline   Reply With Quote
Old   March 22, 2012, 07:49
K.M.Yang
Hi,friend
I haven't work out that problem yet. Are you interested in this problem or somrthing like this?
Old   March 28, 2012, 00:29
Haider Muhammad
haider760 is on a distinguished road
I was also trying to use phase change model for mixture flows inside condenser tube but unfortunately the model is extremely disappointing so far!
IPMT rates are actually negligible.
Have you come up with some solution?
haider760 is offline   Reply With Quote
Old   March 28, 2012, 02:28
Default HI
Danial
Hey ! i am also working on some solidification model (including phase change) but unfortunately stuck with some MPF error. still working on it. I am trying fluent for solidification now.
u can try" Leap australia"; its some kind of support group for ansys users. just send them ur problem and they would help u to find out any error. it might be helpful for u!!they gave me some suggestions and i ma working on it.
Old   March 28, 2012, 03:38
K.M.Yang
Tkanks for your information! I will send message to them!
Thermal phase change model Piti CFX 1 January 14, 2021 10:03
simulation of phase change material melting rosol FLUENT 4 December 8, 2015 07:56
water 2 phase, Change from hight to low temp panuwat FLUENT 0 June 19, 2006 08:50
How to Model Three Phase Clay Slurry in CFX 5.5 J.Yang CFX 2 August 28, 2002 12:06
Phase change modelling Sebastien DANIEL FLUENT 1 July 6, 2000 03:35
