Wind load on surface => Turbulence modelling
Old   March 7, 2012, 10:57
Default Wind load on surface => Turbulence modelling
Merend
pz1337 is on a distinguished road
i am trying to modell the load on surface by the wind, using
- power law for the inlet velocity
- sand grain roughness on the ground
- keps or kw-sst modell
in ansys cfx 14.0
Wind velocity are hitting the surface around 15m/s. I have pressure measurements from a wind tunnel - but they do not match.
Can you advise me on
(1) which turbulence model is better?
(2) how can i (iteratively) see how fine i have to resolve the mesh near the surface?
Thanks a lot in advance!
pz1337 is offline   Reply With Quote
Old   March 7, 2012, 11:09
Merend
i get a converged solution using kw sst and a first cell height of 0.01m on the surface. When I changed that to 0.005m (Using Inflation, First Cell height@0.005m, max Layers: 15, ratio 1.2 to achieve a smooth transition to the sorrounding area).
I get very bad convergence, osciallating at around 5e-4 (comparing to 1e-6) before.
any advice on this? I am sure there is a simple explanation.
Thanks again
Old   March 7, 2012, 17:02
Have you seen these FAQ:
http://www.cfd-online.com/Wiki/Ansys...gence_criteria
http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
Old   March 7, 2012, 17:07
Merend
thank you - yes I have.
I am constantly working on the problem and was hoping for some suggestions to speed things up as I am working on the problem already for quite some time and each new calculation takes several hours.
Modelling a burning surface morne OpenFOAM Running, Solving & CFD 5 April 29, 2015 08:56
Modelling wind through trees Anna Davis Main CFD Forum 1 September 17, 2008 08:33
Turbulence modelling Panos Siemens 6 July 8, 2004 02:40
Turbulence model in flow driven by surface tension Z. ZENG Main CFD Forum 7 April 28, 1999 07:18
Wind Turbine Modelling Neil Campbell Main CFD Forum 1 November 10, 1998 19:03
