error message
Old   March 18, 2012, 06:36
Default error message
cuteapathy is on a distinguished road
hi everyone,
I am a new user for CFX so I might ask some stupid questions here. Sorry for that. My question is when I set up my boundary condition, there are always some error messages. In the detail of my boundary, I set my Flow Direction to be Zero Gradient and then I got the error message:
Expression resolves to invalid units ('m s^-1') in value set for
parameter 'Unit Vector X Component' in object '/FLOW:Flow Analysis
1/DOMAIN: Default Domain/BOUNDARY:Inlet1/BOUNDARY CONDITIONS/FLOW
DIRECTION'. Expected units: 'dimensionless'.
parameter 'Unit Vector Y Component' in object '/FLOW:Flow Analysis
There are no 'Unit Vector X Component' and 'Unit Vector X Component' these two terms in the option of Flow Direction so I have no idea how to make it right. Could anyone help me? Thank you.
cuteapathy is offline   Reply With Quote
Old   March 18, 2012, 16:49
The error message seems pretty clear to me. The direction vector should be unitless but it is getting a number with units of velocity.
Can you post your CCL?
Old   March 19, 2012, 02:59
My expressions:
Boundary Pressure
250*(cos(2*x/1[m])+cos(2*y/1[m]))*exp(-4*0.000001002*t/1[s])*1[kg]/1[m]/1[s]/1[s]
Boundary X Velocity
sin(x/1[m]) *cos(y/1[m])*exp(-2*0.000001002*t/1[s])*1[m]/1[s]
Boundary Y Velocity
-cos(x/1[m])*sin(y/1[m])*exp(-2*0.000001002*t/1[s])*1[m]/1[s]
Initial Pressure
250*(cos(2*x/1[m])+cos(2*y/1[m]))*1[kg]/1[m]/1[s]/1[s]
Initial X Velocity
sin(x/1[m])*cos(y/1[m])*1[m]/1[s]
Initial Y Velocity
-cos(x/1[m])*sin(y/1[m])*1[m]/1[s]
I apply Boundary pressure in the Static Pressure of option of Mass and Momentum on my Boundary-Inlet1 and Boundary-Inlet2. And, I apply Boundary X Velocity and Boundary Y Velocity in the Cart. Vel. Components of the option of Mass and Momentum on my Boundary-Outlet1 and Boundary-outlet2.
At first, I tried to apply both of pressure and velocity on all of my boundarys, but it did not work. So I adjusted to apply pressure on my inlets and velocity on my oulets.
Are the problems about my expressions? Thank you for your response.
Old   March 19, 2012, 03:59
Please post your CCL.
Old   March 19, 2012, 04:09
Lance
Lance is on a distinguished road
You get the error because you have specified static pressure on the inlet and at the same time an expression that resolves to [m/s] for the flow direction settings. The flow direction settings should be dimensionless if you want to specify it.
Also, setting both pressure and velocity on the same boundary is not possible.
Lance is offline   Reply With Quote
Old   March 19, 2012, 04:24
I am sorry to ask a stupid question here. I checked CFX tutorial and tried to find the file of CCL. I could not find where it is. Could you tell me how I could find it? Thank you very much.
Old   March 19, 2012, 04:25
Lance
File/export/ccl
Old   March 19, 2012, 04:42
Dear Lane,
I set my Flow Direction to be Zero Gradient. I have no idea how I could fix this problem. Could you help me? Thank you very much.
Old   March 19, 2012, 04:44
Lance
Old   March 19, 2012, 05:21
My CCL:
LIBRARY:
CEL:
EXPRESSIONS:
Boundary Pressure = \
250*(cos(2*x/1[m])+cos(2*y/1[m]))*exp(-4*0.000001002*t/1[s])*1[kg]/1[m\
]/1[s]/1[s]
Boundary X Velocity = sin(x/1[m]) \
Boundary Y Velocity = \
Initial Pressure = 250*(cos(2*x/1[m])+cos(2*y/1[m]))*1[kg]/1[m]/1[s]/1[s]
Initial X Velocity = sin(x/1[m])*cos(y/1[m])*1[m]/1[s]
Initial Y Velocity = -cos(x/1[m])*sin(y/1[m])*1[m]/1[s]
END
Coord Frame = Coord 0
Domain Type = Fluid
Location = B16
BOUNDARY: Inlet1
Boundary Type = INLET
Location = Inlet1
BOUNDARY CONDITIONS:
FLOW DIRECTION:
Option = Zero Gradient
END
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
Option = Static Pressure
Relative Pressure = Boundary Pressure
END
END
END
BOUNDARY: Inlet2
Location = Inlet2
FLOW DIRECTION:
END
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
END
END
END
BOUNDARY: Outlet1
Boundary Type = OUTLET
Location = Outlet1
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
Option = Cartesian Velocity Components
U = Boundary X Velocity
V = Boundary Y Velocity
W = 0 [m s^-1]
END
END
END
BOUNDARY: Outlet2
Location = Outlet2
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
W = 0 [m s^-1]
END
END
END
BOUNDARY: Wall
Boundary Type = WALL
Location = F17.16,F18.16
MASS AND MOMENTUM:
Option = No Slip Wall
END
END
END
Old   March 19, 2012, 05:39
Remove the "Zero Gradient" direction option in your inlet and use the default normal to boundary option.
Also note this is only part of your CCL. The solver options and materials are not included.
Old   March 19, 2012, 06:24
Dear Glenn,
Do I need to remove the Zero Gradient in my outlets too?
The CLL:
LIBRARY:
MATERIAL GROUP: Air Data
Group Description = Ideal gas and constant property air. Constant \
properties are for dry air at STP (0 C, 1 atm) and 25 C, 1 atm.
END
MATERIAL GROUP: CHT Solids
Group Description = Pure solid substances that can be used for conjugate \
heat transfer.
END
MATERIAL GROUP: Calorically Perfect Ideal Gases
Group Description = Ideal gases with constant specific heat capacity. \
Specific heat is evaluated at STP.
END
MATERIAL GROUP: Constant Property Gases
Group Description = Gaseous substances with constant properties. \
Properties are calculated at STP (0C and 1 atm). Can be combined with \
NASA SP-273 materials for combustion modelling.
END
MATERIAL GROUP: Constant Property Liquids
Group Description = Liquid substances with constant properties.
END
MATERIAL GROUP: Dry Peng Robinson
Group Description = Materials with properties specified using the built \
in Peng Robinson equation of state. Suitable for dry real gas modelling.
END
MATERIAL GROUP: Dry Redlich Kwong
in Redlich Kwong equation of state. Suitable for dry real gas modelling.
END
MATERIAL GROUP: Dry Soave Redlich Kwong
in Soave Redlich Kwong equation of state. Suitable for dry real gas \
modelling.
END
MATERIAL GROUP: Dry Steam
Group Description = Materials with properties specified using the IAPWS \
equation of state. Suitable for dry steam modelling.
END
MATERIAL GROUP: Gas Phase Combustion
Group Description = Ideal gas materials which can be use for gas phase \
combustion. Ideal gas specific heat coefficients are specified using \
the NASA SP-273 format.
END
MATERIAL GROUP: IAPWS IF97
Group Description = Liquid, vapour and binary mixture materials which use \
the IAPWS IF-97 equation of state. Materials are suitable for \
compressible liquids, phase change calculations and dry steam flows.
END
MATERIAL GROUP: Interphase Mass Transfer
Group Description = Materials with reference properties suitable for \
performing either Eulerian or Lagrangian multiphase mass transfer \
problems. Examples include cavitation, evaporation or condensation.
END
MATERIAL GROUP: Liquid Phase Combustion
Group Description = Liquid and homogenous binary mixture materials which \
can be included with Gas Phase Combustion materials if combustion \
modelling also requires phase change (eg: evaporation) for certain \
components.
END
MATERIAL GROUP: Particle Solids
Group Description = Pure solid substances that can be used for particle \
tracking
END
MATERIAL GROUP: Peng Robinson Dry Hydrocarbons
Group Description = Common hydrocarbons which use the Peng Robinson \
equation of state. Suitable for dry real gas models.
END
MATERIAL GROUP: Peng Robinson Dry Refrigerants
Group Description = Common refrigerants which use the Peng Robinson \
END
MATERIAL GROUP: Peng Robinson Dry Steam
Group Description = Water materials which use the Peng Robinson equation \
END
MATERIAL GROUP: Peng Robinson Wet Hydrocarbons
equation of state. Suitable for condensing real gas models.
END
MATERIAL GROUP: Peng Robinson Wet Refrigerants
END
MATERIAL GROUP: Peng Robinson Wet Steam
of state. Suitable for condensing steam modelling.
END
MATERIAL GROUP: Real Gas Combustion
Group Description = Real gas materials which can be use for gas phase \
END
MATERIAL GROUP: Redlich Kwong Dry Hydrocarbons
Group Description = Common hydrocarbons which use the Redlich Kwong \
END
MATERIAL GROUP: Redlich Kwong Dry Refrigerants
Group Description = Common refrigerants which use the Redlich Kwong \
END
MATERIAL GROUP: Redlich Kwong Dry Steam
Group Description = Water materials which use the Redlich Kwong equation \
END
MATERIAL GROUP: Redlich Kwong Wet Hydrocarbons
END
MATERIAL GROUP: Redlich Kwong Wet Refrigerants
END
MATERIAL GROUP: Redlich Kwong Wet Steam
END
MATERIAL GROUP: Soave Redlich Kwong Dry Hydrocarbons
Group Description = Common hydrocarbons which use the Soave Redlich Kwong \
END
MATERIAL GROUP: Soave Redlich Kwong Dry Refrigerants
Group Description = Common refrigerants which use the Soave Redlich Kwong \
END
MATERIAL GROUP: Soave Redlich Kwong Dry Steam
Group Description = Water materials which use the Soave Redlich Kwong \
END
MATERIAL GROUP: Soave Redlich Kwong Wet Hydrocarbons
END
MATERIAL GROUP: Soave Redlich Kwong Wet Refrigerants
END
MATERIAL GROUP: Soave Redlich Kwong Wet Steam
equation of state. Suitable for condensing steam modelling.
END
MATERIAL GROUP: Soot
Group Description = Solid substances that can be used when performing \
soot modelling
END
MATERIAL GROUP: User
Group Description = Materials that are defined by the user
END
MATERIAL GROUP: Water Data
Group Description = Liquid and vapour water materials with constant \
properties. Can be combined with NASA SP-273 materials for combustion \
modelling.
END
MATERIAL GROUP: Wet Peng Robinson
in Peng Robinson equation of state. Suitable for wet real gas modelling.
END
MATERIAL GROUP: Wet Redlich Kwong
in Redlich Kwong equation of state. Suitable for wet real gas modelling.
END
MATERIAL GROUP: Wet Soave Redlich Kwong
in Soave Redlich Kwong equation of state. Suitable for wet real gas \
modelling.
END
MATERIAL GROUP: Wet Steam
equation of state. Suitable for wet steam modelling.
END
MATERIAL: Air Ideal Gas
Material Description = Air Ideal Gas (constant Cp)
Material Group = Air Data, Calorically Perfect Ideal Gases
Option = Pure Substance
Thermodynamic State = Gas
PROPERTIES:
Option = General Material
EQUATION OF STATE:
Molar Mass = 28.96 [kg kmol^-1]
Option = Ideal Gas
END
SPECIFIC HEAT CAPACITY:
Option = Value
Specific Heat Capacity = 1.0044E+03 [J kg^-1 K^-1]
Specific Heat Type = Constant Pressure
END
REFERENCE STATE:
Option = Specified Point
Reference Pressure = 1 [atm]
Reference Specific Enthalpy = 0. [J/kg]
Reference Specific Entropy = 0. [J/kg/K]
Reference Temperature = 25 [C]
END
DYNAMIC VISCOSITY:
Dynamic Viscosity = 1.831E-05 [kg m^-1 s^-1]
Option = Value
END
THERMAL CONDUCTIVITY:
Option = Value
Thermal Conductivity = 2.61E-2 [W m^-1 K^-1]
END
ABSORPTION COEFFICIENT:
Absorption Coefficient = 0.01 [m^-1]
Option = Value
END
SCATTERING COEFFICIENT:
Option = Value
Scattering Coefficient = 0.0 [m^-1]
END
REFRACTIVE INDEX:
Option = Value
Refractive Index = 1.0 [m m^-1]
END
END
END
MATERIAL: Air at 25 C
Material Description = Air at 25 C and 1 atm (dry)
Material Group = Air Data,Constant Property Gases
PROPERTIES:
EQUATION OF STATE:
Density = 1.2 [kg m^-3]
Option = Value
END
Option = Value
END
REFERENCE STATE:
Reference Temperature = 20 [C]
END
DYNAMIC VISCOSITY:
Option = Value
END
Option = Value
Thermal Conductivity = 2.61E-02 [W m^-1 K^-1]
END
Option = Value
END
Option = Value
END
REFRACTIVE INDEX:
Option = Value
END
THERMAL EXPANSIVITY:
Option = Value
Thermal Expansivity = 0.003356 [K^-1]
END
END
END
MATERIAL: Aluminium
Material Group = CHT Solids, Particle Solids
Thermodynamic State = Solid
PROPERTIES:
EQUATION OF STATE:
Density = 2702 [kg m^-3]
Molar Mass = 26.98 [kg kmol^-1]
Option = Value
END
Option = Value
Specific Heat Capacity = 9.03E+02 [J kg^-1 K^-1]
END
REFERENCE STATE:
Reference Specific Enthalpy = 0 [J/kg]
Reference Specific Entropy = 0 [J/kg/K]
END
Option = Value
Thermal Conductivity = 237 [W m^-1 K^-1]
END
END
END
MATERIAL: Copper
PROPERTIES:
EQUATION OF STATE:
Density = 8933 [kg m^-3]
Molar Mass = 63.55 [kg kmol^-1]
Option = Value
END
Option = Value
Specific Heat Capacity = 3.85E+02 [J kg^-1 K^-1]
END
REFERENCE STATE:
END
Option = Value
Thermal Conductivity = 401.0 [W m^-1 K^-1]
END
END
END
MATERIAL: Soot
Material Group = Soot
PROPERTIES:
EQUATION OF STATE:
Density = 2000 [kg m^-3]
Molar Mass = 12 [kg kmol^-1]
Option = Value
END
REFERENCE STATE:
Option = Automatic
END
Absorption Coefficient = 0 [m^-1]
Option = Value
END
END
END
MATERIAL: Steel
PROPERTIES:
EQUATION OF STATE:
Density = 7854 [kg m^-3]
Molar Mass = 55.85 [kg kmol^-1]
Option = Value
END
Option = Value
Specific Heat Capacity = 4.34E+02 [J kg^-1 K^-1]
END
REFERENCE STATE:
END
Option = Value
Thermal Conductivity = 60.5 [W m^-1 K^-1]
END
END
END
MATERIAL: Water
Material Description = Water (liquid)
Material Group = Water Data,Constant Property Liquids
Thermodynamic State = Liquid
PROPERTIES:
EQUATION OF STATE:
Density = 1000 [kg m^-3]
Molar Mass = 18.02 [kg kmol^-1]
Option = Value
END
REFERENCE STATE:
Reference Specific Enthalpy = 0.0 [J/kg]
Reference Specific Entropy = 0.0 [J/kg/K]
END
DYNAMIC VISCOSITY:
Dynamic Viscosity = 0.001002 [kg m^-1 s^-1]
Option = Value
END
Absorption Coefficient = 1.0 [m^-1]
Option = Value
END
Option = Value
END
REFRACTIVE INDEX:
Option = Value
END
END
END
MATERIAL: Water Ideal Gas
Material Description = Water Vapour Ideal Gas (100 C and 1 atm)
Material Group = Calorically Perfect Ideal Gases, Water Data
PROPERTIES:
EQUATION OF STATE:
Option = Ideal Gas
END
Option = Value
Specific Heat Capacity = 2080.1 [J kg^-1 K^-1]
END
REFERENCE STATE:
Reference Pressure = 1.014 [bar]
Reference Temperature = 100 [C]
END
DYNAMIC VISCOSITY:
Dynamic Viscosity = 9.4E-06 [kg m^-1 s^-1]
Option = Value
END
Option = Value
Thermal Conductivity = 193E-04 [W m^-1 K^-1]
END
Option = Value
END
Option = Value
END
REFRACTIVE INDEX:
Option = Value
END
END
END
END
FLOW: Flow Analysis 1
SOLUTION UNITS:
Angle Units = [rad]
Length Units = [m]
Mass Units = [kg]
Solid Angle Units = [sr]
Temperature Units = [K]
Time Units = [s]
END
ANALYSIS TYPE:
Option = Transient
EXTERNAL SOLVER COUPLING:
Option = None
END
INITIAL TIME:
Option = Automatic with Value
Time = 0 [s]
END
TIME DURATION:
Option = Total Time
Total Time = 1 [s]
END
TIME STEPS:
Option = Timesteps
Timesteps = 0.01 [s]
END
END
Domain Type = Fluid
Location = B16
BOUNDARY: Inlet1
Location = Inlet1
FLOW DIRECTION:
END
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
END
END
END
BOUNDARY: Inlet2
Location = Inlet2
FLOW DIRECTION:
END
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
END
END
END
BOUNDARY: Outlet1
Location = Outlet1
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
W = 0 [m s^-1]
END
END
END
BOUNDARY: Outlet2
Location = Outlet2
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
W = 0 [m s^-1]
END
END
END
BOUNDARY: Wall
MASS AND MOMENTUM:
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
Option = Non Buoyant
END
DOMAIN MOTION:
Option = Stationary
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
END
END
FLUID DEFINITION: Water
Material = Water
Option = Material Library
MORPHOLOGY:
Option = Continuous Fluid
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
HEAT TRANSFER MODEL:
Option = None
END
THERMAL RADIATION MODEL:
Option = None
END
TURBULENCE MODEL:
Option = Laminar
END
END
END
INITIALISATION:
Option = Automatic
INITIAL CONDITIONS:
Velocity Type = Cartesian
CARTESIAN VELOCITY COMPONENTS:
U = Initial X Velocity
V = Initial Y Velocity
W = 0 [m s^-1]
END
STATIC PRESSURE:
Relative Pressure = Initial Pressure
END
END
END
OUTPUT CONTROL:
RESULTS:
File Compression Level = Default
Option = Standard
END
END
SOLVER CONTROL:
ADVECTION SCHEME:
Option = High Resolution
END
CONVERGENCE CONTROL:
Maximum Number of Coefficient Loops = 10
Minimum Number of Coefficient Loops = 1
Timescale Control = Coefficient Loops
END
CONVERGENCE CRITERIA:
Residual Target = 1.E-4
Residual Type = RMS
END
TRANSIENT SCHEME:
Option = Second Order Backward Euler
TIMESTEP INITIALISATION:
Option = Automatic
END
END
END
END
COMMAND FILE:
Version = 13.0
END
Old   March 19, 2012, 06:27
I tried to run CFX solution and the system showed the error message:
Error! The CFX Solver for system Fluid Flow (CFX) did not produce a
results file. Detailed information can be found in the output file for
the run, which can be viewed by selecting Display Monitors from the
Solution component. C5
Does this mean there are still problems in my CFX-Pre? Thank you.
Old   March 19, 2012, 18:32
That is a workbench error message. You need to look in the output file to see the detail of the error.
Old   March 20, 2012, 06:45
Dear Glenn,
I will check my output file. Thank you very much. I appreciate your help.
