A challenge for you in cfd(pipe problem)
Like Tree1Likes
  • 1 Post By Far
Old   March 22, 2012, 06:09
Default A challenge for you in cfd(pipe problem)
mahe
mahesh9 is an unknown quantity at this point
Background and Problem Statement:
The manifolds used in the Actuation systems of the aircraft have the control logic inside it. This manifold will house different kind of valves, transducers, solenoids etc. It is always a challenge to provide the flow path between different components with the minimum pressure drop through the flow holes created for the purpose keeping in mind the structural failures thus maintaining thickness of material between the flow holes. And also to keep the total size to minimum and within the specified envelope. So there is always a need to have the flow paths having different orientations within the manifold.
The current problem addresses this requirement using CFD to execute the comparative studies of the pressure drop for various orientations of the flow paths.
The geometry needs to be created using any CAD software similar to the picture below with different orientations.Extract the fluid domain, and bring into theANSYS CFX software to perform the analysis
Inputs:
• Inlet pressure = 5000 psi
• Flow rate = 16 cis
• Fluid: Skydrol/Red Oil.
• (Properties can be obtained from the internet)
• Min dia holes: 0.2 in
• Max dia of flow holes: 0.35 in
• Test block size: 3.5 in *3.5in *1.75in
Expected outputs:
• Pressure and velocity plots for at least 2 different orientations of the flow paths
• Hand calculation of the pressure drop using the standard flow equations and verify the CFD results
THE DIAGRAM OF THE MANIFOLD IS ATTACHED.PLEASE FIND THE ATTACHMENT AND GIVE A REPLY.there is only one inlet and one outlet.the small hole which is made in the block is to connect inlet pipe and outlet pipe.small diameter pipe is to connect inlet and outlet pipes.later on it will be closed with a cap.
mahesh9 is offline   Reply With Quote
Old   March 22, 2012, 07:22
Raja_Bhai
tauqirnawaz is on a distinguished road
What is your question?
tauqirnawaz is offline   Reply With Quote
Old   March 22, 2012, 09:45
mahe
apply boundary conditions according to values and design an orientation with minimum pressure drop or else calculate for same orientation
Old   March 22, 2012, 10:39
Raja_Bhai
How much is the prize money?
Old   March 22, 2012, 14:52
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
I guess should be proportional to question size and no of questions
tauqirnawaz likes this.
Far is offline   Reply With Quote
Old   March 22, 2012, 17:01
Have you considered using the design optimisation stuff built into Workbench?
But this looks a little trivial for that - why not simply make the flow holes as big as possible and as short as possible? That is going to be pretty close to minimum flow resistance. There will be small optimisations to be had by corner details, but I suspect they will be minor.
ghorrocks is online now   Reply With Quote
Old   March 22, 2012, 23:26
mahe
how much is the prize money? :d
prize money 1000 usd
Old   March 22, 2012, 23:45
Far
Sijal
you sure isn't it very low compared to license fees and man hours required
Do you want to extract the fluid volume and apply the appropriate boundary condition?
Old   March 23, 2012, 18:05
Raja_Bhai
not worth it, should at least be £10,000.00
Old   March 24, 2012, 10:53
Far
Sijal
Could you please explain your problem exactly?
[Other] engineFoam new mesh problem ayhan515 OpenFOAM Meshing & Mesh Conversion 5 August 10, 2015 08:45
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
