April 14, 2012, 11:41 |
Can CFX run 2D problems
Rep Power: 16 |
Hi I need to ask can I run 2 D mesh geometries within CFX?
Mariam Sara |
April 14, 2012, 13:07 |
Taleb Zarei
Rep Power: 14 |
HI
CFX has a 3D Space. if you want to have a 2D simulation, you have to draw a geometry in 2D and with a small thickness ( this geometry is in 3D but solved in 2D). define both side of thickness as symmetry. See tutorial 7 of CFX tutorial 11.0 (free surface flow over bump) |
April 15, 2012, 08:09 |
Rep Power: 16 |
Did you mean I need to draw the geometry as 3D and give the third dimension as small thickness and give it symmetry boundary? I use Gambit for mesh is it suitable for CFX?
April 15, 2012, 10:35 |
Taleb Zarei
Rep Power: 14 |
Hi
Yes. I am using CFX-mesh for meshing. In CFX-mesh, you can meshing 2D geometry by " extruded 2D mesh" tools. I dont know Gambit. |
April 15, 2012, 13:58 |
Rep Power: 16 |
CFX pre can import Gambit Mesh it work fine with it. You said in your reply I need to use small thickness for the third dimension I need to ask how much thickness I need to use ? for example I want to draw rectangular channel with 2 m length and 0.5 m height if I take the third dimension thickness as 0.1 m is this value suitable or should I reduce it more to solve it as 2 D problem in CFX?
Thanks a lot Mariam |
April 16, 2012, 10:38 |
Rep Power: 16 |
Hello talebzarei may you send me the steps of drawing the mesh in Bump tutorial in CFX-Mesh or Icem I am really new with both of these programs and need to follow your steps to create my channel with it?
April 17, 2012, 00:19 |
DB
Rep Power: 15 |
Hi Mariam,
You just need two cells along thickness ( not sure about one, check the fact in tutorial). Just keep a small portion of thickness no need for too thick a mesh.
-D.B |
April 17, 2012, 00:37 |
Rep Power: 16 |
Thanks D.B for the reply. As I mentioned I am new with ICEM and CFX-Mesh so I need to ask if my channel length is 8 m and height is 0.1 m if I chose the third dimension as 0.001 m (i.e. 1 mm) is it sufficient or i need make it smaller?
April 17, 2012, 01:04 |
#9 |
DB
Rep Power: 15 |
Hi Mariam,
I think you just take a look at CFX tutorial, and see if their thickness is vaguely different from other dimensions. I had once done this for a cylindrical geometry and used only 1 degree of the sector for a diameter of approx 600 mm
-D.B |
April 17, 2012, 01:06 |
#10 |
Rep Power: 143 |
This is covered in the FAQ, including the recommended thickness for the third dimension extrusion.
http://www.cfd-online.com/Wiki/Ansys..._simulation.3F |
April 17, 2012, 01:14 |
#11 |
Rep Power: 16 |
Thanks guys for the valuable information. I am wondered how I can view the mesh file for the bump tutorial (paratran file) within CFX-mesh?
April 19, 2012, 04:16 |
for your help
#12 | |
Safia
Rep Power: 15 |
Ihope that help. Regards |
May 5, 2012, 03:19 |
#13 |
Rep Power: 16 |
Thanks Happy for the reply. May you please illustrate me to how I can use sweep mesh method and define the symmetry faces as target and source through mesh set up which you mentioned in your last post? you mean I need to apply this in CFX-Pre or in ICEM? I use Gambit for mesh because I not have wide experience with ICEM and CFX-mesh is this can be done in Gambit?
May 5, 2012, 07:14 |
#14 |
Rep Power: 143 |
Since CFX V13 (I think) CFX-Pre has been able to import gambit meshes, including 2D meshes. When CFX gets a 2D mesh it automatically extrudes it 1 element. So you cen generate your geometry in gambit as a 2D model and load it directly in CFX-Pre.
May 5, 2012, 14:26 |
#15 |
Rep Power: 16 |
I was imported 2d mesh file from gambit into CFX-Pre I have CFX 12.1 release I think CFX make the mesh as 3D truly but the problem I not see the front and back faces which need to be set as symmetry as the guys mentioned I found the boundaries I define in gambit such as, inlet,outlet,downwall,upwall and CFX add unknown boundaries I not understood what they represents they are primitive 2D A and primitive 2D B are these boundaries the sides of the geometry that needed to be set as symmetry? here is a link for the mesh file in CFX-Pre attached at the link below.
http://www.2shared.com/file/1Aswm-4I/meshtwo.html |
May 5, 2012, 22:19 |
more explaining
#16 | |
Safia
Rep Power: 15 |
May 6, 2012, 10:08 |
#17 |
Rep Power: 16 |
Thanks I use Gambit now. Glenn may you have a look on the mesh I sent in my above post I import it from Gambit as 2D please let me know if there is any problem with it?
May 6, 2012, 20:14 |
#18 |
Rep Power: 143 |
I do not have the time to look at your files.
CFX-Pre extrudes 2D meshes from Gambit, so if you cannot see it then it probably has only done a tiny extrusion. This is often bad as it means the aspect ratio of the resulting elements is terrible. Under the advanced mesh import options I think there is an option to define how far CFX-Pre extrudes the mesh. You need to increase that number. |
May 7, 2012, 00:48 |
#19 | |
Rep Power: 16 |
I saw the third dimension in my mesh there is one element on it and when I press mesh statistics CFX give me the following about it:
min x ,max x: 0,25 min y,max y: 0,0.0985 min z,max z : -0.001,0 all dimension in meters. As seen the last dimension is the extruded one which it 1 mm so is it sufficient or i need to increase extrude factor (currently 1) at advance import options? Quote:
May 7, 2012, 07:02 |
#20 |
Rep Power: 143 |
CFX thermo-fluid 2D simulation problems | maryliz | CFX | 6 | October 31, 2011 23:26 |
CFX problems with supersonic inlet condition - Inlet values in CFX-Post are wrong | jannnesss | CFX | 5 | February 25, 2011 16:24 |
Problems with importing ICEM-CFD mesh in CFX | signofra | CFX | 3 | March 3, 2010 10:08 |
Problems on running cfx in parallel | Nan | CFX | 1 | March 29, 2006 04:10 |
run Build Topology in IcemCFD 4 CFX | Ahmed | CFX | 3 | March 19, 2004 16:59 |
