Home > Forums > Software User Forums > Edge
ffa2engold and lambda2 problems
Old   February 2, 2012, 09:02
Default ffa2engold and lambda2 problems
Olle Bodin
olle.b is on a distinguished road
Hello
I am trying unsuccessfully to convert my results to ensight format incuding lambda 2. To output is as follows:
[x_ollbo@neolith1 scania_fine_EDGE_steady_200g]$ ffa2engold -cb -l2 ../fine_extruded.bedg fine_extruded.aboc fine_extruded.bmsh
fine_extruded.bout L2_inst_fine
ffa2engold version $Rev: 2379 $ is starting...
Processing steady grid and steady solution.
All EnSight Gold data files will be stored on C Binary format.
Adding lambda2 field.
Reading mesh file "fine_extruded.bmsh".
Update mesh to multi-region format
-- Done reading.
Analyzing mesh data
-- Warning! There will be a loss in precision, since only
single precision is allowed in EnSight Gold format.
Writing file "L2_inst_fine.geo".
-- Done analyzing.
Reading solution file "fine_extruded.bout".
Update solution to multi-region format
Solution already in multi-region format
-- Done reading.
Update boundary to multi-region format
BOUNDARY already in multi-region format
ERROR IN MODULE FFA, ROUTINE "FFFSDS" !!!
--- DATASET NOT ASSOCIATED, SEARCHING FOR n_edges ---
ERROR IN MODULE FFA, ROUTINE "IVALUX" !!!
--- STRING "n_edges" NOT FOUND ---
STOPPING EXECUTION!!
I have done this before but it was quite a while ago, what am I doing wrong? I am using Edge 5.2 (r2568) both for the calculation and for the attempted postprocessing. Any help would be greatly appreciated!
mvh, Olle
olle.b is offline
Old   February 24, 2012, 14:25
jka
Adam Jirasek
jka is on a distinguished road
were you able to solve your problem?
jka is offline
Old   February 27, 2012, 08:16
Olle Bodin
No, I have not been able to solve this. To be honest, I have not started looking through the code for ffa2engold yet which I suspect will be necessary as I do not understand the error message.
The string "n_edges" is present in the *.bedg file which I assume this part is about:
But, as I wrote, this error does not make sense to me so I need to understand what ffa2engold does when it gives this error. Right now I do not have time for this but I will update the thread when I do.
olle.b is offline
Old   February 27, 2012, 16:18
jka
Adam Jirasek
Sure, keep me up on your progress, I'll check it out too and if I find something I let you know.
jka is offline
Old   February 28, 2012, 03:51
jka
Adam Jirasek
Just checked the ffa2engold and seems to be working fine for me, this is an output. Check your bedg file with ffalist:
ffa2engold -cb -l2 Mesh.bedg Mesh.aboc Mesh.bmsh Edge.bout test2
Reading mesh file "Mesh.bmsh".
-- Done reading.
Analyzing mesh data
Writing file "test2.geo".
-- Done analyzing.
Reading solution file "Edge.bout".
-- Done reading.
EnSight solution analysis.
Writing file "test2.density".
-- Done writing.
Writing file "test2.velocity".
-- Done writing.
Writing file "test2.pressure".
-- Done writing.
Writing file "test2.turb_viscosity".
-- Done writing.
Writing file "test2.rans_viscosity".
-- Done writing.
Writing file "test2.Cp".
-- Done writing.
Writing file "test2.temperature".
-- Done writing.
Writing file "test2.mach".
-- Done writing.
Writing file "test2.Cp_total".
-- Done writing.
Writing file "test2.Po_Po_inf".
-- Done writing.
Writing file "test2.lambda2".
-- Done writing.
/opt/common/bware/x86_64/edge/trunk/bin//fb2cb
Casename: test2
Converting the following files ['test2.geo', 'test2.density', 'test2.velocity', 'test2.pressure', 'test2.turb_viscosity', 'test2.rans_viscosity', 'test2.Cp', 'test2.temperature', 'test2.mach', 'test2.Cp_total', 'test2.Po_Po_inf', 'test2.lambda2'] to C Binary format.
Done converting test2.geo
Done converting test2.density
Done converting test2.velocity
Done converting test2.pressure
Done converting test2.turb_viscosity
Done converting test2.rans_viscosity
Done converting test2.Cp
Done converting test2.temperature
Done converting test2.mach
Done converting test2.Cp_total
Done converting test2.Po_Po_inf
Done converting test2.lambda2
this is my ffalis of bedg file (just the first MG level)
jka is offline
ffa2engold, lamda2, postprocessing
