Home > Forums > Mesh Generation & Pre-Processing Software > enGrid
Problem going from surface to volume mesh
Old   November 22, 2013, 07:45
Default Problem going from surface to volume mesh
zaman is on a distinguished road
Hello everyone,
I am currently having great difficulty doing the volume mesh of a simple naca0012 wing, check surface integrity is fine and no overlapping surfaces are found. I believe this is an unprecedented bug, whatever the way I do the surface mesh, Engrid stops at "blockfill local h", it doesn't crash but the next step seems impossible to start.
I enclosed my case and geometry, thanks in advance!
Mark
zaman is offline   Reply With Quote
Old   November 26, 2013, 02:03
Oliver Gloth
ogloth is on a distinguished road
Hello Mark,
I have downloaded your case and will have a look at it and keep you updated.
Best regards,
Oliver
ogloth is offline   Reply With Quote
Old   January 9, 2014, 08:05
Hello Oliver,
Any luck with my mesh?
Regards,
Mark
Problem of simulating of small droplet with radius of 2mm liguifan OpenFOAM Running, Solving & CFD 5 June 3, 2014 02:53
[ICEM] How to generate sunstructured "all-tri patch-dependant" surface mesh in ICEM? jash ANSYS Meshing & Geometry 19 July 23, 2013 18:48
[blockMesh] Problem with Mesh Volume seboxx OpenFOAM Meshing & Mesh Conversion 3 January 30, 2012 08:19
