Home > Forums > Software User Forums > Fidelity CFD
help with fine/marine!
Old   March 5, 2013, 10:08
Default help with fine/marine!
ellen lee is on a distinguished road
I am using fine/marine with a planing hull, and the results are not very accurate,I am wondering is it because the froud number is over 3 or still problems with the meshing?
ellen lee is offline   Reply With Quote
Old   March 10, 2013, 08:45
Romain
Rombzh is on a distinguished road
You mean the predicted drag is off ? You might want to increase the y+ value, and already prescribe your final trim value in Hexpress.
Rombzh is offline   Reply With Quote
Old   March 12, 2013, 09:59
you mean fix the trim? but what if i don‘t know the final trim?
Old   March 12, 2013, 11:05
Romain
Well you could use the trim value you got with your first run, even if forces were off, rotate your geometry in Hexpress and build the mesh.
You can also predict your final trim value with Savitsky's formulae.
Old   June 16, 2013, 11:36
KHB
lava12005 is on a distinguished road
have you make sure there is no air entrapment below?
This I found to reduce the viscous drag significantly.
Check your mesh resolution on the transom as well, it needs to be fine enough so that the water separate from the hull nicely.
lava12005 is offline   Reply With Quote
Weighted Deformation Mesh technique in Fine/Marine naimishharpal Fidelity CFD 8 December 11, 2010 17:03
FINE/MARINE Fred Fidelity CFD 1 February 28, 2007 17:18
