Home > Forums > Software User Forums > Fidelity CFD
Igg
Old   September 22, 2010, 06:53
Post Igg
Rajpal Singh Bhadoria
rajpal is on a distinguished road
I am using igg for the aircraft mesh........but i am facing problem to make vortex trail in end of wing...can you tell me that how to use elliptic smooth option............
rajpal is offline   Reply With Quote
Old   January 24, 2011, 07:09
Lightbulb Smooth meshing
sanboju
sanboju is on a distinguished road
Is it your problem, a boundary layer problem? you can define how high you wanna be the increase of the transition mesh adjusting parameters in Grid--> Create face --> planar faces smoothing. You have to define the cell width (is the distance from the wall for the first layer), the control layers number, and expansion ratio for the transition from the first to the last layer.
One recomendation friend, for a good meshing the trailing edge must not finishes in a vortex. You can fill the vortex and for example, cut with a circle of 1-2 diameter.
Another think I recomend you is to remeshing the leading edge and the trailing edge. Once you choose the number of points of the mesh over the upstream and downstream of the wing, you can selec one kind of edges distribution. I recomend you to define an hyperbolic tangent with 0.002 spacing.
When you finish all the steps I tell you, yo have to smooth again.
I hope I'll be helpful.
Cheers
sanboju is offline   Reply With Quote
IGG AUTO-Grid Michael Fidelity CFD 5 May 29, 2017 03:08
Bouncing in IGG Rikio Fidelity CFD 0 November 5, 2007 22:27
Plugin for own output format in Numeca (IGG)... Jaroslaw Rachwalski Fidelity CFD 3 June 25, 2007 11:00
Python Skripts for IGG Ole Ritter Fidelity CFD 2 April 21, 2003 05:02
import lofted surfaces in IGG rolando guerrieri Fidelity CFD 2 April 18, 2003 09:37
