Home > Forums > Software User Forums > Fidelity CFD
Negative cells in AutoGrid
Old   September 7, 2011, 11:10
Default Negative cells in AutoGrid
Matthias
funmaker is on a distinguished road
Hello everybody,
i have created a wind turbine geometry in IGG and try to generated a mesh in AutoGrid using the wind turbine wizzard. Everything is working fine. I import and link the geometry in AutoGrid by defining a suction and pressure side, leading and trailing edge and also shroud and hub.
In the B2B view i got sharp edges on the leading and trailing edge position because opened airfoil profiles. To get rounded edges i use the option blend the blade at leading/trailing edge. All this works great.
But by generating the 3D mesh for the blade and far field i get negative cells.
Thy reach from the center of blade tip into the far field.
Maybe one of you could give me and advice.
Kind regards Matthew
funmaker is offline   Reply With Quote
Old   September 17, 2011, 11:15
totti
totti9090212 is on a distinguished road
Hi, i think your geometry( bad geometry ) and poor gird distributed may lead negtive cells. see the b2b view of the position which have negtive cells. from it , you could find which cause negtive cells. if your geometry is good, you can adjust the gird points, cell width and expansion ratio to improve your grid quality.
totti9090212 is offline   Reply With Quote
Old   July 17, 2012, 04:58
venkatesh
venkat_aero2007 is on a distinguished road
Have you solved the problem of negative cells in farfield. I have the same problem. Could you please help me to solve this problem. I tried to change span wise distribution and expansion ration but all these didn't work.
venkat_aero2007 is offline   Reply With Quote
Old   July 17, 2012, 05:17
Matthias
Hi venkat_aero2007,
sorry for my late answere.
Yes, i solved the problem with the negative cells.
In my case i had to create the virtuell shroud-line above the blade. So that there is no intersection between the shroud-line and the blade. This sounds confusing but it worked.
I hope i could help you.
Old   July 17, 2012, 05:34
venkatesh
Hi funmaker,
Thanks for your reply. Could you please tell me, What do you mean by "virtuell shroud-line". Does it mean you created a shroud line at the end of the far field and defined that has shroud. Could you please explain a bit more. And how long was your field?. Do you created two shroud line and define one has a shroud and other as what??
Actually my blade have a shroud gap of 0.25mm. I have a good quality mesh in the region of blade. But I get negative cells only in the far field. the negative cells are located in the blade tip block just above the shroud and continues till the far field.
Thanks in advance for your information. waiting for your reply.
negative cells, wind turbine
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
physical boundary error!! kris Siemens 2 August 3, 2005 00:32
