Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Critical Temperature of Liquids
Old   March 18, 2015, 03:53
Default Critical Temperature of Liquids
Raghav
raghav612 is on a distinguished road
Hello all,
Is it possible to operate fluids like pentane, hexane, butane etc above their critical temperature? If yes, then what are its consequences? If not, how do i determine the maximum pressure and teperature under which they can be operated?
Ps: sorry for the error
raghav612 is offline   Reply With Quote
Old   March 18, 2015, 09:14
Disabled
Boris_M will become famous soon enough
I'm confused. Do you mean to use them as gas passing the critical pressure becoming liquid or as liquid passing the critical pressure? I'm asking because your header was kind of misleading to the rest of the post.
In general you can use Real Gas as a fluid which considered the supercritical region too. But you will need the properties as only Methane and Propane is available in the database.
Boris
Boris_M is offline   Reply With Quote
Old   March 18, 2015, 09:31
Raghav
Hello Boris,
Sorry there was a mistake on my side. I am operating the fluid just below its critical pressure but above its critical temperature. Is this scenario practically possible?
Ps: I am trying to simulate a Rankine Cycle
#rankinecycle, #thermodynamics
Shadow Wall and temperature norger FLUENT 10 September 28, 2019 11:43
fluid flow but temperature raises from nowhere? mxcfd STAR-CCM+ 5 September 16, 2014 05:46
Inlet won't apply UDF and has temperature at 0K! tccruise Fluent UDF and Scheme Programming 2 September 14, 2012 06:08
difference of temperature HKH FLUENT 0 January 28, 2010 02:45
monitoring point of total temperature rogbrito FLUENT 0 June 21, 2009 17:31
