Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
FloEFD > Viscosity as Goal
Old   November 26, 2015, 03:10
Default FloEFD > Viscosity as Goal
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
In the results, I find the goal-summary very usefull and also representative for the set up of the calculation.
But I am missing the fluid viscosity.
I always run calculations with constant viscosity (so floefd is solving the energy equation for peanuts > is there a way to deactivate the energy equation? I am not interested in the temperature distribution)
Back to my initial question: I would like to see the viscosity range in the goal-summary (excel export).
I tried to introduce a goal relating to the viscosity withot any success.
Thank you
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   November 30, 2015, 08:07
Disabled
Boris_M will become famous soon enough
Hi Maxime,
the viscosity is part of the fluid property and changes over the temperature.
So you would need the temperature to get to that property.
What you could do is to use the data in the Engineering Database on the viscosity and put it in Excel. Create a fitting curve on it and use the equation that describes the curve in an equation goal with the temperature at the location you are interested in from another goal as a goal dependency in the equation goal to calculate the dynamic viscosity of the fluid.
Would that work for you?
Boris
Boris_M is offline   Reply With Quote
Old   November 30, 2015, 08:21
-mAx-'s Avatar
Maxime Perelli
yes it should work, but as I said, I don't work with temperature.
In the Fluid Database I only create fluid with constant viscosity (independantly from temperature) (One fluid per temperature, for instance oil at 0°C / oil at 20°C and so on)
Doing that I don't look after the temperature in the BC.
I thought we could also add the viscosity as a Goal just like the density (which is also a fluid property)
Old   November 30, 2015, 08:44
Disabled
Ok, I understand. So you have just a fixed value for isothermal simulations. I thought any heat transfer into the solids but maybe mixing fluids with different temperatures and therefore varying viscosities.
So you just want to use the fixed value in a calculation such as Re number but need to enter it manually all the time. Is that what your issue is?
Boris
Old   November 30, 2015, 08:51
-mAx-'s Avatar
Maxime Perelli
exactly, only isothermal with only one phasis.
At the end I only want to have my constant viscosity as goal (I know it is a given parameter), just to be sure I was running with right viscosity range
Problem with divergence TDK FLUENT 13 December 14, 2018 06:00
Ratio of eddy viscosity to molecular viscosity : Laminar or turbulent flow? JuPa CFX 7 September 9, 2013 07:45
Too low temperature at combustor outlet romekr FLUENT 2 February 6, 2012 10:02
modelling solids viscosity in eulerian multiphase model derkaiser FLUENT 1 December 5, 2011 03:42
kinematic viscosity at diff temperatures,pressures Mecobio Main CFD Forum 0 November 7, 2005 12:55
