February 16, 2016, 05:12 |
Surface Goals in External flow
Rep Power: 10 |
I am trying to obtain surface goals of the external flow. I was wondering how I can achieve this without creating a solid surface. What I essentially want is an area goal. Any tips?
February 22, 2016, 06:56 |
Rep Power: 10 |
I am still having troubles with this. What I want is the average temperatures and pressures at a specific cross section of the computational domain. There are no surfaces at that point.
So far, the only option I could think of was taking a lot of points on the plane of interest, and then averaging. However , this sounds extremely tedious. Is there anyway to apply a surface goal to a plane? |
February 22, 2016, 07:02 |
A. Lindgren
Rep Power: 10 |
I am not sure if this works, but have you tried to create a solid body with a surface where you want to apply the SG and then deactivate it in Component Control (then it is considered as fluid). That way you have a surface to apply your SG to.
I have not tried it, but its worth a try. |
February 22, 2016, 07:07 |
Rep Power: 10 |
I was debating trying that, but I thought if the solid was deactivated the surface would be too.
I'll give it a shot and then post an update! |
February 22, 2016, 09:39 |
Rep Power: 10 |
I tried to surpress the solids after specifying the surface goals. It would produce an error saying the surface is not defined.
In the end, I decided to use the tedious point goal average approach. I have began to introuduce 25 point goals across my area of 7x3 mm to begin my validation of results. I will take the average of these and see how it compares with the experimental results. |
February 22, 2016, 10:11 |
A. Lindgren
Rep Power: 10 |
Did you suppress it in Component Control?
If you look in tutorial C5 (Rotating Impeller), there is a example of the use of a deactivated solid to put a SG on. |
February 22, 2016, 16:06 |
Rep Power: 10 |
Thanks, I'll take a look at that tutorial tomorrow. It sounds like just what I'm looking for
February 23, 2016, 05:10 |
Rep Power: 10 |
Yup, it worked out. Thank you!
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
trying to simulate two-phase jet flow with particles in surface injection | ajkratos | FLUENT | 5 | March 3, 2015 21:33 |
[OpenFOAM] Compute Surface Flow & Integral | Victorien | ParaView | 0 | July 8, 2014 05:57 |
For a single phase flow, is there any way to check water surface level? | Tanjina | FLUENT | 0 | February 23, 2014 22:56 |
Flow over surface | Duncan | FLUENT | 0 | January 26, 2006 11:05 |
