Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
swirl flow in FolwWork Simulation
Old   May 23, 2011, 06:20
Question swirl flow in FolwWork Simulation
Larry Lin
linsir0825 is on a distinguished road
Hi All
I have a question about the swirl flow setting.When I let the Fan inlet be a swirl flow,FlowWork Simulation will ask me to enter two value
1. Angular Velocity
2. Radial Velocity
Angular Velocity is the Fan rotation speed ????
And how to calulate the Radial Velocity ???
linsir0825 is offline   Reply With Quote
Old   June 7, 2011, 05:02
Disabled
Boris_M will become famous soon enough
Hi Larry,
if you define a swirl flow in a regular boundary condition your flow has three components, the axial (perpendicular to the inlet surface), the angular velocity which is the rotating speed (RPM or rad/s) as you can see from the units and the radial velocity is the velocity you have in radial direction in case the fan creates not a cylindrical flow but a cone like flow outwards like diagonal fans do.
For a regular "Fan curve"-Fan you have to set the angular velocity and the radial velocity as it is not defined in the fan data and the axial velocity is corresponding to the fan curve unlike for a regular boundary condition where there is not a fan curve related to.
For an "Axial Fan"-Fan from the database the angular velocity is defined in the database settings of the fan as rotating speed and the radial velocity is calculated from the inner and outer hub diameter which describe the two hub diameters on both sides of the fan. If they are not the same, you would define a diagonal fan if they are the same it is a straight blowing axial fan. So here these values are defined and calculated from the database.
I hope this helps,
Boris
Boris_M is offline   Reply With Quote
Help with slug flow simulation. Kes FLUENT 3 November 9, 2019 21:39
Swirl diffuser flow lpy2009 FLUENT 2 January 8, 2015 02:20
Problems about multi swirl tubes simulation using Jason FLUENT 4 May 9, 2008 00:33
Expert parameter to stop the fluid flow simulation KK CFX 1 February 25, 2008 16:29
2D Flow Simulation Sethu Raghavan Main CFD Forum 0 October 18, 2001 01:12
