Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Several continueus fans in a long tube SwFlo
Old   April 15, 2012, 16:45
Default Several continueus fans in a long tube SwFlo
Kirilo, Konstantin
kkpanayotov is on a distinguished road
Greetings to all,
I have a question regarding a big model ( 800 meters long) which i am thinking of making a simulation of it .
The simple model for the simulation will include a wind tunnel of around 800 meters , intake from one side, outtake on the other, AND Several Small Fans ( only on the top side of the tunnel ) located in different distances from each other .
The whole idea is the air taken from the intake to pass through the fans and to see how the intake air is moved through the tunnel.
I started testing the idea with but the insert of "Internal fan" as an option does not take anything at all from the intake side and only gives to the Outtake side.
Have some one faced this issue ? I will be grateful for any comments...
Cye...
kkpanayotov is offline   Reply With Quote
Old   April 23, 2012, 23:20
WookJin Kim
JosephKim is on a distinguished road
I think you should use "local rotate" method than "Internal fan"..
I can't explain in detail but if you teach me your e-mail address, I can send a material related to "local rotate" method.
JosephKim is offline   Reply With Quote
Old   April 24, 2012, 01:15
Kirilo, Konstantin
You have got a PM...
Old   April 24, 2012, 01:37
WookJin Kim
PM? Patent?
I don't understand.. Anyway this material is released for everyone.
Old   April 24, 2012, 02:26
Kirilo, Konstantin
PM = Private massage
Sorry for that...
Old   April 27, 2012, 02:30
WookJin Kim
I didn't know private massage function.
I sent a e-mail. Good luck.
Old   May 4, 2012, 15:59
Disabled
Boris_M will become famous soon enough
I think the problem with your internal fan is that internal fan doesn not mean you have to use this fan in an internal analysis.
The internal fan is for a fan that sits in somewhere in the calculation area and has two faces to the fluid around it, one is sucking the air in the other is blowing the air out. If you want to use a fan on your inlet, then it is an external inlet fan as the fan is mounted externally and blows the air into the fluid region. For the external outlet fan it is also mounted externally but is sucking the air out. so just like an inlet or outlet condition.
But if you have the fan geometry and want to really see how the air is moving around the blades of the fan you should go with the local rotation as Joseph says.
Boris
Boris_M is offline   Reply With Quote
Old   May 4, 2012, 16:06
Kirilo, Konstantin
Thanks to all..
The idea is that inside the computational domain , there is an fan, which i don't have any data regarding it's geometry except that i know the fan inlet/outlet speeds...
That is why i wanted to know if someone has faced this problem.
Yes i can make a model of the fan and make it work with rotation until i reach the speeds that i know, but still i wanted to know if there is a way around that ...
Thank you ..
If you have any idea regarding this "way around" i will be greatfull to get it posted...
Thanks
Old   May 4, 2012, 16:09
Disabled
Well for this fan you would need the fan curve as it depends on the pressure difference between the two sides of the fan. If you have that data from a datasheet you can simply create your own fan curve with that data and use that.
Boris
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
OpenFOAM-1.5-dev svn revision 1438: libOpenFOAM does not compile in SP 4xF OpenFOAM Bugs 3 October 16, 2009 05:35
Missing math.h header Travis FLUENT 4 January 15, 2009 11:48
How to model a long tube embedded in the earth? stefanie FLUENT 2 May 17, 2007 14:35
long tube mesh asghari FLUENT 2 June 8, 2006 12:49
