Home > Forums > Software User Forums > FLOW-3D
natural convection boundary condition
Old   June 22, 2012, 12:14
Unhappy natural convection boundary condition
Xiaohu Yang
thomasyangfly is on a distinguished road
Hello all dear,
I am doing the cooling problem of a block of liquid aluminum filled in container. I want to see how long it takes to cool down the liquid to solid with natural convection thermal boundary condition. However, unfortunately, I cannot find how to set the thermal boundary condition as natural convection.
Please help me. Thanks a lot!
thomasyangfly is offline   Reply With Quote
Old   June 22, 2012, 14:19
dmilano is on a distinguished road
You can set the heat transfer coefficient in the "surface properties" section of the tree on the M&G tab. If you leave the heat transfer coefficient =-1 the code will estimate what the HTC should be based on correlations. You can also estimate what the HTC is from a correlation and input this directly. Finally, you can assume that the HTC is very large and that conduction in the fluid is the controlling parameter. To use this assumption, just put in a large value for the HTC but you'll need to make sure that the assumption is physically valid.
dmilano is offline   Reply With Quote
Old   August 24, 2012, 02:38
Smile
Xiaohu Yang
Thank you very much for the kindly help.
Old   September 11, 2012, 10:14
Stefano
stefmascio is on a distinguished road
you will also have to switch on the density evaluation model (and setting a thermal expansion coefficient) if you want to see convective motions inside the water.
stefmascio is offline   Reply With Quote
mixed inflow/outflow downstream boundary condition question peob OpenFOAM Running, Solving & CFD 3 February 3, 2017 10:54
natural convection problem with radiation jorien CFX 0 October 14, 2011 09:26
boundary conditions for Natural Convection problem Nav CFX 13 June 6, 2011 07:37
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 20:28
Rotating interpolated boundary condition hani OpenFOAM Running, Solving & CFD 0 July 4, 2006 07:09
