Home > Forums > Software User Forums > FLOW-3D
how to show the temperature distribution of the mould
Old   August 24, 2012, 03:43
Red face how to show the temperature distribution of the mould
Xiaohu Yang
thomasyangfly is on a distinguished road
Hello guys,
I am doing the simulation about the solidification of water in a Al mould, but unfortunately I do not know how to display the temperature distribution on the Al mould.
Besides, if I set the heat transfer to fluid 1 as "-1",will the software calculate the heat transfer coefficient via correlations?
Please do me a favor.
Thanks all.
thomasyangfly is offline   Reply With Quote
Old   August 24, 2012, 11:32
dmilano is on a distinguished road
This will only work if the fluid to solid heat transfer option is set to full energy equation.
For 2D plots: Analyze->2D->Contour variable = wall temperature
For 3D plots: Analyze->3D->Iso-surface = complement of volume fraction, color variable = wall temperature
dmilano is offline   Reply With Quote
Old   August 26, 2012, 09:21
Xiaohu Yang
Thank you very much for your kindly help.
I got it.
temperature distribution inside droplet? ljp Fluent UDF and Scheme Programming 1 June 7, 2017 01:38
Strange temperature distribution by adding 'Gravity' fshak92 STAR-CCM+ 5 May 21, 2012 07:13
High temperature methane+air Peter FLUENT 5 January 26, 2009 18:04
An issue with temperature change in unsteady prob Ashok kumar FLUENT 1 January 13, 2009 04:34
Temperature local distribution on the boundary Matteo Siemens 0 January 10, 2007 07:18
