Home > Forums > Software User Forums > FLOW-3D
How do I model a sub-critical flow with FLOW-3D?
Old   November 8, 2012, 16:31
Default How do I model a sub-critical flow with FLOW-3D?
abbas bakhtiari
abbaspwut is on a distinguished road
Hi dear
I want to model a sub-critical flowin FLOW-3D.
When the height of the lower boundary is greater than of the upper boundary the water will enter the downstream boundary of the computational region.
As a result of my assumptions is destroyed.
Please help me
abbaspwut is offline   Reply With Quote
Old   November 10, 2012, 14:24
max
max0014 is on a distinguished road
Originally Posted by abbaspwut View Post
Hi dear
Please help me
I don't see why the water enters the downstream when height of the downstream boundary is greater than upper boundary?
max0014 is offline   Reply With Quote
Old   November 11, 2012, 04:40
abbas bakhtiari
Ask better questions:
Why height of downstream is not more than height of upstream?
if y2>y1 then flow-3d enter water of downstream boundary condition.
y2=height of downstream
y1=height of upstream
i want y2>y1 and flow direction is upstream --> downstream but after Run flow direction is downstream --> upstream
Old   November 11, 2012, 04:44
abbas bakhtiari
Hi dear
Please help me
Old   November 27, 2012, 11:37
Jeff Burnham
JBurnham is on a distinguished road
FLOW-3D is a transient solver. You are using assumptions of steady-state gradually-varied flow. The only way to model this kind of situation is to include the control structure that causes the downstream free surface elevation to be higher than the upstream elevation. That is, you must model the contraction, critical transition structure, or bed elevation change explicitly, instead of assuming that by setting h2 > h1 you can force FLOW-3D to assume that the flow is steady/gradually-varied.
JBurnham is offline   Reply With Quote
How to model granular flow through porous media Axius FLUENT 2 August 7, 2014 10:34
Non-steady flow simplified for use in Vissim steamerandy Main CFD Forum 0 October 31, 2011 21:08
Coupling Radiation with Flow model tongx051 FLUENT 0 October 22, 2011 16:03
How to model flow of centrifugal fan? Peter Main CFD Forum 0 April 2, 2008 06:07
Baldwin-Lomax model in wall jet flow K.S.Chang Main CFD Forum 0 December 7, 2005 01:51
