May 29, 2016, 13:14 |
Problems for Stepped Spillways Modelling
Sayed-Abdol-Hamid Sajjadi
Rep Power: 9 |
Dear all
what models must be activated for investigating the influence of 1. Void Fraction 2. bubbles 3. Cavity length ? i activated these models but it does NOT generate good results : Air entrainment Density evaluation Drift-flux Gravity Surface tension Viscosity thank you |
July 20, 2016, 11:14 |
kaouachi anouar
Rep Power: 9 |
Hello Dear are you successful for simulation of water over stepped spillways ? we can cooperate for this simulation
July 29, 2016, 00:52 |
Yu Zhou
Rep Power: 12 |
July 30, 2016, 19:24 |
kaouachi anouar
Rep Power: 9 |
thank you so much for your reply im phd student i want make Scientific article about the flow over stepped spilways Using cfd ?
July 31, 2016, 22:48 |
Yu Zhou
Rep Power: 12 |
August 1, 2016, 08:46 |
kaouachi anouar
Rep Power: 9 |
So can you send my your email?
August 2, 2016, 04:21 |
Yu Zhou
Rep Power: 12 |
August 2, 2016, 12:23 |
Daniel
Rep Power: 15 |
Dear Sayed (et al.),
you can find some description on models used for this type of simulation under the following link: http://89.31.100.18/~iahrpapers/80300.pdf There is also some discussion on the results: air entrainment, free surface roughness and velocity profiles. Best regards, D. |
August 5, 2016, 10:55 |
#9 | |
Rep Power: 9 |
actually i simulated the stepped spillway before and i extracted the results too, but my problem is a big deviation between the experimental and numerical data. the maximum values of spillway volume is 1 m , 1.4 m and 1.4 m on a Cartesian axis and i assume a 2.6* 1.6*1 m^3 mesh block using 0.5 to 1 cm mesh size for modelling , if you are curious about that. i had to plot the air entertainment into the fluid flow over the spillway and i calculate that by fraction of fluid. when i compare the figures with the experimental figures, there is a deviation unfortunately. i will be grateful if you share your experience with me. thank you. |
August 6, 2016, 07:15 |
#10 |
Daniel
Rep Power: 15 |
Dear Sayed,
my experience is: when using FLOW-3D's air entrainment model, you can reproduce the inception point location as shown in the above posted paper or in Bombardelli et al (2011). If you are interested in the velocity profiles, these 2 papers show also some comparison, and the one posted above also discusses on the free surface roughness. If you want to reproduce accurately the air concentrations, you will have to do some calibration of C_{air}, this is also discussed in the above posted paper. If you want to get some more ideas on this type of calibrations, I carried out one for smooth spillways a few years ago which you can find in my Research Gate profile. Best regards, Daniel |
August 6, 2016, 17:04 |
#11 | |
Rep Power: 9 |
August 7, 2016, 20:54 |
#12 | |
Yu Zhou
Rep Power: 12 |
thanks daniel. I will read them carefully. |
April 13, 2019, 17:18 |
#13 | |
Ysmn
Rep Power: 8 |
Hello, I could not reach the link. Can you please send a new link to reach these documents? Thank you in advance! Yasemin |
August 20, 2019, 07:43 |
#14 | |
zohran arif
Rep Power: 8 |
December 18, 2019, 05:51 |
#15 | |
Ysmn
Rep Power: 8 |
Sorry, but still not available. Thank you! Yasemin |
December 18, 2019, 06:27 |
#16 |
Ysmn
Rep Power: 8 |
I am trying to simulate a stepped spillway which ends with a stilling basin in FLOW-3D. I have confused about using one-phase model with activated air-entrainment model or two-phase model. I need to calculate cavitation risk through the spillway. I have started with one-phase non-air entrainment model. After 30 seconds run, I added restart simulation with an air-entrainment model. Now, I am trying to add another restart simulation with two-fluids selection without air-entrainment model and it gives error below: "Possible two-fluid velocity slip problem. Density ratio greater than 10 to 1. Consider using slip option. ifslip=1" Also, I am curious about dividing geometry into small parts and run them one by one to save time. I read about it but I confused how to connect boundaries each other. Could you please share your experiences? Thank you in advance, Yasemin |
December 18, 2019, 06:31 |
#17 |
zohran arif
Rep Power: 8 |
December 18, 2019, 07:56 |
#18 | |
Ysmn
Rep Power: 8 |
Yasemin |
May 10, 2020, 06:08 |
#19 |
Najam us Saqib
Rep Power: 5 |
Hi every one.MY name is najam and I from Pakistan.I have just started using flow 3D.I am just a beginner in FLOW 3D.I am using flow 3D for my master thesis.My topic is ''Numerical modeling of stepped spillway using FLOW 3D".
For my first stage of my thesis I am doing model calibration where I am getting experimental results from a paper and I trying to validate it with my model results in flow 3D. The paper provides experimental pressure profiles at vertical and horizontal faces of steps. I am getting the values pressure at the mesh nodes closest to the horizontal and vertical face of steps.But i am getting significantly large values as compared to paper. I am using RNG model.Also I have used Gravity and no inertial frame Viscosity and turbulence Can any one help me to figure out where I am doing the mistake. |
May 11, 2020, 10:33 |
#20 | |
Ysmn
Rep Power: 8 |
Unfortunately, I am not familiar with the Flow 3D. However, your calibration step is the most difficult part for all numerical models. Did you do mesh independence analysis? I mean, is your mesh fine enough to solve the model? Also, have you checked enough points to decide that the gap is so large between experimental and numerical model? Thank you, Yasemin |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
Problems when compile SU2 v4.X with openmpi | BopngMa | SU2 | 1 | September 6, 2015 06:30 |
Problems when modelling flow through syringe, error in dynamic initialization | Sudarsan1805 | FLUENT | 3 | September 2, 2015 02:19 |
Some problems with Star CD | Micha | Siemens | 0 | August 6, 2003 13:55 |
liquid/solide phase change problems | mehdi fteity | Main CFD Forum | 3 | September 14, 2000 21:44 |
