Home > Forums > Software User Forums > FLOW-3D
defining bondaries in multy-blocks
Like Tree1Likes
  • 1 Post By JBurnham
Old   December 18, 2012, 02:21
Default defining bondaries in multy-blocks
jacky831 is on a distinguished road
Hi, there.
The problem i face is how to define bondary type in the connection of two blocks.
The model i created must use sevral blocks to cover,at first i used symmetry bondary to define the connection of two blocks ,but in the analys tab i only can see the part in the first block,the others are missing. then i tried the specified pressure bondary type, it did'nt work either. now i am confused about it. Can you help me?( the model is a spillway.)
thanks!
Best regards!
jacky831 is offline   Reply With Quote
Old   December 18, 2012, 18:00
Jeff Burnham
JBurnham is on a distinguished road
You don't need to specify any particular boundary type at the interface of two blocks. The interface has to line up exactly (if the blocks are 'linked'), or the smaller block needs to be inside the larger block entirely. On the Analyze tab, look for the 'Mesh Blocks' button at the bottom and make sure all blocks are activated for display.
zandi likes this.
JBurnham is offline   Reply With Quote
Old   December 18, 2012, 20:31
so just specify the ‘linked’ block according to the default Settings ?
Old   December 22, 2012, 14:25
zandi's Avatar
Fatema Zandi Goharrizi
zandi is on a distinguished road
I don't know how to make it linked but I specified the joint boundary as 'symmetry' and simulate it. it wroks. I wonder is it correct or not?
zandi is offline   Reply With Quote
Old   November 7, 2013, 15:21
Flowdy
Flowdy is on a distinguished road
In the code of the case you should put ibct(5)=9, in the right mesh
IBCT(n)
Boundary condition type at mesh block boundaries
1, = symmetry plane
2, = rigid wall
3, = continuative boundary
4, = periodic boundaries (must be applied at opposite sides of mesh)
5, = specified pressure boundary
6, = specified velocity boundary
7, = boundary values obtained from previous calculation using grid overlay (GO) procedure
8, = outflow boundary that minimizes wave reflections
9, = inter-block boundary
10, = surface wave boundary (for n=1, 2, 3 and 4 only)
11, = specified flow rate boundary (Volume flow rate)
Flowdy is offline   Reply With Quote
[Commercial meshers] fluent3DMeshToFoam bego OpenFOAM Meshing & Mesh Conversion 31 August 16, 2023 09:04
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 05:59
dsmcInitialise - dsmcFoam archymedes OpenFOAM Pre-Processing 94 July 15, 2016 16:14
[snappyHexMesh] Meshing multiple blocks Hanno OpenFOAM Meshing & Mesh Conversion 3 February 17, 2011 12:14
Merging the blocks in ICEM saisanthoshm88 ANSYS Meshing & Geometry 1 December 27, 2010 10:14
