December 13, 2014, 15:47 |
Creating slope of channel bed
RoyDaniel
Rep Power: 11 |
Hi All Flow 3D users,
I've just created simple rectangular open channel. but the channel bed still doesn't have slope. I am wandering how to make a slope of the channel bed. Could any body help me how the way to create bed slope? In creating bed slope I think there are two things that I think should be considered first the sub-component, this one can possible to rotate and the second is Mesh which cannot be rotated. Please see attached file the open channel which I've made with zero of bed slope. Thank you so much for your help Best Regards, Roy. |
December 15, 2014, 14:17 |
Jeff Burnham
Rep Power: 17 |
Either make a solid component for the bed and rotate it (and translate it if necessary), or set gravity GX and GZ both, using trigonometry to figure out how much is GZ and how much is GX - this is like rotating the frame of reference.
December 18, 2014, 10:32 |
RoyDaniel
Rep Power: 11 |
Hi Jeff,
Thank you so much! for your help, Now I am trying solving it like your advise and also may be other way too.. I'll let you know, for interesting result of my model. My best Regards.. Roy Daniel |
How did I set two kind of slope in channel ? | Marco | FLOW-3D | 9 | August 30, 2022 08:07 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
rough bed open channel flow | ati_ros61 | FLOW-3D | 1 | October 28, 2011 00:58 |
meshing the bed of a channel | antonio | ANSYS Meshing & Geometry | 3 | March 4, 2010 10:42 |
Creating a grid for a channel inside a brick | sanin | FLUENT | 0 | November 6, 2008 08:03 |
