Home > Forums > Software User Forums > FLOW-3D
urgent problem : fluid height
Old   December 9, 2013, 10:16
Exclamation urgent problem : fluid height
ouni firas
ounifiras is on a distinguished road
Dear experts :
I am trying to simulate a flow through a labyrinth weir. I put a condition to limit the left limit Xmin specific pressur (fluid height = 5.34 m) for X max It was puted as an overflow, Ymin Ymax & & Zmin Were puted as a Wall, Zmax WAS puted as symmetry , the initial condition for the fluid height was 5.34m. after completing the simulation OF RESULTS are shown in figures, the problem is that the height of the fluid does not remain constant, but for the example Weir height the fluid remains constant. i want to know how to have an initial height of fluid constant for all time
ounifiras is offline   Reply With Quote
Old   December 9, 2013, 10:47
Jeff Burnham
JBurnham is on a distinguished road
It sounds like you set it up right, just like the Example simulation (Flow Over a Weir). Did you make an initial fluid region for fluid at t = 0? You should do that as well to speed up the time to steady state. After you do that, check your boundary conditions again and make sure they're what you described, because they sound correct. Good luck.
JBurnham is offline   Reply With Quote
Old   December 9, 2013, 10:55
ouni firas
Dear Jeff Burnham
I did not understand the initial fluid for fluid region at year t = 0. I have a condition that limits Xmin I put as specific pressur (Fluid height = 5.34m) and I created a fluid Region with ZLow = 0 and Zhight = 5.34m. i did not Understand the initial fluid for fluid Region at year t = 0.
Thanks greatly
Old   December 9, 2013, 11:00
Jeff Burnham
An initial fluid region is the same. It is fluid location at t = 0. Check that you have Gravity physics active, and that gz is negative (pointing downward), e.g. gz = -9.81 (if you're using SI units).
Old   December 9, 2013, 11:32
ouni firas
yes i use the SI and gz = -9.81 . for the Xmax wich is puted as Outflow, can it cause a problem? In the exemple (Weir) I found this remark in the '' &bcdata'' : pbctyp=1.0, remark='specified boundary p=0.0 is stagnation pressure' AND fbct(1,5)=0., remark='no fluid below bottom boundary', . do you think that they have any influence in this problem
thank you greatly .
Old   December 9, 2013, 12:26
Jeff Burnham
Outflow boundaries are only correct when Froude number Fr > 1 (supercritical flow) at the boundary. If flow is subcritical (Fr <= 1), then Outflow will drain out the flow, so use a pressure-type boundary instead, with stagnation option checked and specified fluid elevation.
Old   December 9, 2013, 17:17
ouni firas
thank you greatly
Mr Burnham do you think that the lenght of the chanel influence in the initial condition because this problem appear just with the channel wich has 100m as a lenght ?
microfluid fluid structure interacion problem sorrego CFX 0 July 2, 2012 15:16
Non-newtonian fluid results problem. fruitkiwi Main CFD Forum 4 June 26, 2012 09:39
Urgent; convergence problem in MRF simulation Mansureh ANSYS 4 February 2, 2011 06:00
Urgent, Urgent, a UDF problem, PLEASE HELP!!! Max FLUENT 1 September 24, 2010 20:30
Jet flow problem.. PLZ help URGENT!! Vinayak CFX 1 April 3, 2008 18:02
