Home > Forums > Software User Forums > FLOW-3D
Sediment layer for scouring problem
Old   February 20, 2014, 02:49
Default Sediment layer for scouring problem
Sugonghak PC Bang
sycst911 is on a distinguished road
Hello everyone. I am still new to scouring simulation in Flow-3D. I have a basic question to ask, which is "How to generate sediment layer for scouring simulation?".
I have specified my initial fluid region, especially the Z minimum. Is everything below Zmin sediment? Else how do I "place"/"locate" my sediment? I know my flow depth, and I would like the sediment to be right below the flow depth. But how?
Also, an extra small question is that what does "packed sediment concentration" mean? How to actually determine the value?
Appreciate if anyone could help. Thanks!
sycst911 is offline   Reply With Quote
Old   March 1, 2014, 08:02
mohsen
m.poorjafar is on a distinguished road
you must define component and select " packed sediment" in component type,then edit it in subcomponent-limiters
m.poorjafar is offline   Reply With Quote
Old   March 2, 2014, 19:49
Sugonghak PC Bang
Thanks m.poorjafar. But I'm using 9.3 version. Probably I don't have the features you mentioned above...? o.O
Old   March 4, 2014, 17:14
mohsen
in this version : in "initial" , front the packed sediment, specified density of sediment, and in "limiters" specified location of packed sediment
Old   March 6, 2014, 06:52
Sugonghak PC Bang
Ok.thanks.
By the way, one very simple yet "deadly" question. what is the viscosity of water at 20 degree (in SI unit)? I found out it should be 1.0E-06, but why is the default setting in Flow 3D shows 0.001? I am confused. Please help!!
Old   March 6, 2014, 20:37
Sugonghak PC Bang
sorry. I have found the answer. thanks!
Old   March 6, 2014, 20:41
Sugonghak PC Bang
My last problem remaining is that my sediment tends to be washed off too easily within seconds. I am not sure how to manipulate it despite varying all the values of "critical sediment fraction", "cohesive sediment fraction", "packed sediment concentration". Manipulating these values seem doesnt help much.. Is there any other way to make my sediment binds more tightly (higher cohesiveness)? obviously i couldnt change the sediment diameter, density, Shields parameter, etc. Please help me...
*Why is the angle of repose -90? I thought it is supposed to be 30 for sand, normally speaking.
High aspect ratio mesh problem for flat plate boundary layer sam1364 OpenFOAM 3 May 14, 2020 11:11
[snappyHexMesh] SnappyHexMesh: Layer on corners Pj. OpenFOAM Meshing & Mesh Conversion 9 July 17, 2014 04:26
[snappyHexMesh] Boundary layer in a pipe Clementhuon OpenFOAM Meshing & Mesh Conversion 6 March 12, 2012 12:41
[snappyHexMesh] Layer addition problem near symmetry planes bigbang OpenFOAM Meshing & Mesh Conversion 6 December 8, 2011 06:35
Flat plate boundary layer problem student Main CFD Forum 3 May 21, 2007 13:10
