June 12, 2014, 22:57 |
particles
汪双君
Rep Power: 12 |
I simulate a gravity casting。In the simulation,I use particles model to model foreign inclusions in liquid metals .But I want to a fixed particles number of 2400,but I set the rate of genaration as 2400,but it produce large than 2400 or less than 2400.How can I set to get a fixed number.
July 5, 2014, 22:41 |
Jeff Burnham
Rep Power: 17 |
Use a particle block instead of a source. The source makes new particles and rate is #/second. The block only makes the particles only once at t = 0.
July 5, 2014, 23:04 |
汪双君
Rep Power: 12 |
thank you for your reply.I will try later. But I have a new problem .when I use particle model to simulate slag.In the course of filling and solidification,I find some particles out of range of casting.How I to do can avoid it?
how to determine the number of particles injected. | welch | FLUENT | 2 | January 18, 2024 04:08 |
UDF for deleting particles in DPM | imanmirzaii | Fluent UDF and Scheme Programming | 12 | November 25, 2020 19:27 |
trying to simulate two-phase jet flow with particles in surface injection | ajkratos | FLUENT | 5 | March 3, 2015 21:33 |
Conditional Release of DPM particles - UDF | nvschandra | Fluent UDF and Scheme Programming | 0 | December 10, 2013 11:02 |
particles model | ati_ros61 | FLOW-3D | 3 | December 6, 2009 16:03 |
