Home > Forums > Software User Forums > FLOW-3D
About adding a heat source to the fluid surface.
Old   October 28, 2018, 23:16
Default About adding a heat source to the fluid surface.
Qiyang He
inner7549 is on a distinguished road
Hello everyone,I'm a beginner of flow-3D,and I'm trying to put a heat source which is able to catch the free surface and heating the fluid at the catched surface from the z-axis direction.
I added these codes in the heatfl.F90,
if (xi(i).lt.(1.0e-4+5e-3*t).and.xi(i).gt.(0.8e-4+5e-3*t).and. &
& yj(j).lt.2.6e-4.and.yj(j).gt.2.4e-4.and. &
& zk(k).lt.1.8e-4.and.zk(k).gt.1.0e-4) then
if (abs(fn(ijk)-0.5).lt.1.and.fn(ijkp).lt.0.6.and.fn(ijkm).gt.0) heatfl1=5e10
endif
and it did add a heat source to the surface, but it just continue finding another mesh cell to add heat source which did not exist since the laser just heat the fluid surface at the top level.
It seems that only ijk, instead of any other cell index can be passed to fn subroutine. So I just want to get a skeleton of flow-3D and make change to other subroutine that can influence the whole process to work as a counter for heating the surface. Or there are any other way to do things like whar I said? Thank you.
inner7549 is offline   Reply With Quote
Old   August 12, 2020, 00:26
小橙
SUTATO is on a distinguished road
i note that free surface elevation(hyel) is the Z-coordinate of free surface. but i can't add the "hyel" into the subroutine.
SUTATO is offline   Reply With Quote
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 08:06
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 17:38
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 17:34
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
