September 30, 2008, 21:29 |
FLOW 3D Meshing
Dear FLOW3D users I'm very happy to find a place for this special kind of software. any way; I want a tutorial for learning most effective way of meshing & girding in this software. any good help and tutorial is appreciated. sincerely.
October 1, 2008, 04:24 |
Re: FLOW 3D Meshing
I need more help for meshing and geometry. Thanks
October 1, 2008, 07:35 |
Why don't you use mid-range 3D CAD S/Ws?
Hi, buddy.
You can make easy the STL file from such mid-range 3D CAD S/W as Solid Edge V20. It's very easy for use. First, draw the spillway structure as 3D solid. Second, export the solid as STL file format. It's over. If you visit "http://cometrue.kr/30", you can see a project of mine. And if you need for help, send me e-mail with drawing of spillway(include weir). |
October 1, 2008, 08:22 |
Effective Way of Mesh Generating...
FLOW-3D includes a me
October 1, 2008, 08:23 |
Re: Effective Way of Mesh Generating...
FLOW-3D includes a mesh generator, supports easy interface after version 9.0. (WYSIWYG, I think so...)
From my experience, I think inputting many fixed grid points(each breakpoint of geometry) is more effective way than increasing the resolution of grid, and avoid multi-block grid as much as possible. I understood the mean of effectivity as only view point of solving time. |
October 1, 2008, 10:51 |
Re: Why don't you use mid-range 3D CAD S/Ws?
Hi, Dear friend I will try in way you said.Do you have any document can help me?
Best regards |
October 1, 2008, 11:07 |
Re: FLOW 3D Meshing
Hi Also i am happy that we have place we can ask our qustions about FLOW-3D. Now i need tutorial for learning most effective way of meshing & griding in this software emergency.
Sincerely |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
flow over a cylinder urgent! | kevin | FLUENT | 8 | August 11, 2015 13:00 |
Meshing for Mutliphase free surface flow | MatzeMas | ANSYS | 2 | August 7, 2009 05:06 |
potential flow vs. Euler flow | curious ... | Main CFD Forum | 23 | July 21, 2006 07:40 |
transform navier-stokes eq. to euler-eq. | pxyz | Main CFD Forum | 37 | July 7, 2006 08:42 |
