Home > Forums > Software User Forums > FLOW-3D
Path Plot Result
Old   April 12, 2009, 03:36
Default Path Plot Result
ck5285 is on a distinguished road
Hi All
It is possible to do a path plot by specify 2 coordinates? for example user just need to defined point A (x1,y1,z1) and B (x2.y2,z2) then it will generate data/results for velocity, pressure or temperature along that line?
ck5285 is offline   Reply With Quote
Old   April 13, 2009, 00:18
michael barkhudarov
MuxaB is on a distinguished road
Hi, I don't think this is possible. Would be nice, really.
Michael
MuxaB is offline   Reply With Quote
Old   April 13, 2009, 03:44
Hi Michael
will this consider as enhancement feature for future release?
CK
Old   April 13, 2009, 11:10
michael barkhudarov
How do you see this feature working in practisc? Would it be like a streamline plot, that is, displayed a colored line?
Old   April 13, 2009, 21:08
It should display as colored line so that user can physically view from post-processing and confirm if this is what they want. Btw, data along that line (temp, velocity, pressure for each coordinate/points along the line) can be export to excel/notepad for further graph plot/analysis by user. So is this doable?
CK
Old   April 14, 2009, 12:35
michael barkhudarov
How many points would you have along the line? Would it be user's input? In any case, this will not be possible in FLOW-3D's post-processor any time soon (this year, for example), but I am usre it is possible in other post-processing packages, like Fieldview or Tecplot.
Old   April 14, 2009, 20:47
The number of data is depends on number of nodes/grid cells along the defined point/line. You are right both Fieldview & Tecplot have the capabilities but the major problem is both are expensive tools and bottom line is why user have to pay more for just post-processing package if this can be done with F3D itself. I don't have the post-processing package as mentioned and it become a problem in data analysis.
Old   April 15, 2009, 14:14
michael barkhudarov
Hi CK,
I understand your point, but by the same token we cannot develop the same post-processing capabilities that FV and TP have since our primary focus is CFD.
To answer you original question - it is not currently possible to display data the way you describe, and we are not planning to have it in this year's release.
Regards,
Michael
Old   April 17, 2009, 01:47
Michael
so any plan to consider this in future?
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
path line and vector plot YK FLUENT 0 August 18, 2008 07:07
One critical error while compiling lam711 billpeace OpenFOAM Installation 0 October 30, 2006 04:41
how 2 plot result data from VR-Viewer in 2 excel anjani dubey Phoenics 3 January 6, 2006 06:19
graph plot anindya Main CFD Forum 2 September 17, 2003 12:00
