April 14, 2009, 16:56 |
data point
Ali Etesam
Hi every body
I use F3D 9.0. I should know pressure & velocity of many points with certain coordinats. but i dont know how do that? can you help me?:confus ed: |
April 14, 2009, 19:30 |
try neutral file.
April 15, 2009, 01:30 |
Data point
Ali Etesam
Hi H.C
I have a warning in neutral file:No coordinate state file( transf.in),can not creat neutral file. what should i do? do you know i want to compute pressure and velocity in certain point that has coordinate such as A(x1,y2,z3),B(x2,y2,z2)........ thank you so much |
April 15, 2009, 10:10 |
make sure the file "transf.in" is in the simulation directory. sometimes users might forget to remove the old extension such as txt. in "transf.in", please add the following lines
-1 0 x1 y1 z1 x2 y2 z2 .... |
August 5, 2016, 04:57 |
this helped me ! when i remove the old extension 'txt' ,then it goes correctly ,thanks a lot !!
IFStream read float point data problem | liu | OpenFOAM Running, Solving & CFD | 0 | October 24, 2008 12:14 |
[Gmsh] Gmsh and samplesurface | touf | OpenFOAM Meshing & Mesh Conversion | 2 | December 10, 2007 02:27 |
extract point data | susan | Siemens | 4 | November 27, 2007 14:04 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
