Home > Forums > Software User Forums > FLOW-3D
Spinning cylinder in viscous liquid - a serious doubt
Old   January 6, 2010, 02:21
Default Spinning cylinder in viscous liquid - a serious doubt
s Kumar
doctsh is on a distinguished road
I have made a cylinder rotating about its axis in a highly viscous liquid (to mimic low reynolds no). according to theory,the cylinder has to move axially forward but in my CFD simulation it goes front and then come back... what could be the reason? I made a mesh as in the GMO sphere example and have given 6 DOF and prescribed rotational motion along cylindrical axis and coupled translational motion along cylndrical axis. other motions i made as prescribed and given 0. I have enabled GMO model and viscosity model. Is there anything wrong with this set up?
Plz some one help me...
doctsh is offline   Reply With Quote
Old   January 6, 2010, 14:52
michael barkhudarov
MuxaB is on a distinguished road
Looks like you did it all right. What makes it theoretically go along the axis?
MuxaB is offline   Reply With Quote
Old   January 11, 2010, 01:20
s Kumar
Thanks a lot. I checked the theory, due to high viscous force there is accumulated azimuthal velocity driving rod in forward direction given by (pls see the attached picture)
Any idea why it is not keep going? Should I give any specific meshing? As I am not welversed in meshing, can you recommend what structure of mesh will be appropriate for my problem (cartesian/cylindrical or fit to geometry/automesh)?
thanks in advance
Old   January 12, 2010, 15:20
Jim Higgs
jhiggs is on a distinguished road
The last time I tried to use cylindrical coordinates, the 0 degree boundary and the 360 degree boundary did not allow flow to pass through from one to the other. I ended up using Cartesian.
jhiggs is offline   Reply With Quote
Old   January 20, 2010, 11:33
michael barkhudarov
The opposite boundaries must be of type periodic for the communication between them to occur.
Regarding meshing the GMO, there is nothing special required for the mesh. Just make sure it resolves the geometry well and leaves room around it for the flow to develop. If the mesh is uniform, so much the better.
Still not sure what the problem looks like. Can you send an image or a drawing?
Old   January 21, 2010, 12:56
s Kumar
see the attached figure:
Cylinder of radius 20nm rotating with its axis around 600 rad/s...
Old   January 22, 2010, 09:20
otd
private
otd is on a distinguished road
I don't understand the physical setup.
Why should the cylinder move? Is it mounted on springs or some sort of arrangement that lets it slide in the xy plane? The diagram shows nothing about the suspension of the rotating cylinder.
The data appear to show an oscillation about a steady state solution. Is it possible that vortices are forming in the corners of the square experimental tank? I'm suggesting circulating in the corners about a vertical axis near each corner.
It could be helpful if you described the physical setup fully. As it stands, it appears that you're comparing two-dimension analysis with three-dimensional data.
otd is offline   Reply With Quote
Old   January 22, 2010, 11:43
s Kumar
Hi
It is actually a nanoscale motor. which drives the cylinder through spinning. when it spins, under low reynolds number environment, due to viscous force it goes forward like a screw. so no spring or any other set up. it is just a cylinder spinning independently.
Old   January 28, 2010, 11:52
michael barkhudarov
Could you please send me your prepin file?
Old   January 30, 2010, 13:49
Default thanks for your insights
s Kumar
Please see the attached prepin file.
Thanks for your support.
Please remember that i am a beginner and tried to implement what i learnt through gmo sphere tutorial.
File Type: zip prepin.zip (659 Bytes, 18 views)
Old   January 31, 2010, 23:37
michael barkhudarov
Thanks for the file. Is the equation for the angular velocity from their book on Hydrodynamics? What section of it and page no?
Old   February 1, 2010, 02:51
s Kumar
Thanks again for supporting me.
The equation is given in page 56 of FLUID MECHANICS
Second Edition
by
L. D. LANDAU and E. M. LIFSHITZ
I have also attached those pages as pictures.
Please have a look on a research paper which explains this in detail:
Mesoscopic Modeling of Bacterial Flagellar Microhydrodynamics (available at
http://www.ncbi.nlm.nih.gov/pmc/articles/PMC1630491/)
I hope this two information will be helpful to understand the problem
thanks
Old   February 1, 2010, 09:17
michael barkhudarov
thanks Kumar,
this will help me to understand the problem. give me a few days to look at it.
Old   February 1, 2010, 22:42
michael barkhudarov
The solution in the Landau book is for the flow of fluid between two rotating cylinders. This kind of motion does not create any propulsion for the cylinders themselves. The paper, on the other hand talks about a rotating helix, in which case there may be propulsion in the axial direction since the helix acts like a screw.
What you need to start with is create a helix in a CAD tool and import it into FLOW-3D as an STl file.
What school do you study at?
Old   February 1, 2010, 23:29
s Kumar
Thanks for your information.
I have done CFD simulation according to an experiment explained in the paper (please have a look on equation 4, and graph: figure-1) :http://www.ncbi.nlm.nih.gov/pmc/articles/PMC1630491/
Here they have showed that there exist a net azimuthal velocity using experimental set-up. I just tried the same in the Flow3d, though I could already observe the same in helix, i could not do for cylinder as explained by them.
By the way I am an Indian physics teacher, teaching in Oman, but still a student in CFD and bacterial motion.
Thanks for your continuous support.
Old   February 2, 2010, 09:17
michael barkhudarov
Net axial or azimuthal velocity? The paper explicitly says that for a smooth cylinder there is no axial motion.
Old   February 2, 2010, 20:44
s Kumar
Ok, sorry I understand. I assumed that the graph (figure -1) shows the velocity, of the cylinder's front surface, so cylinder could move forward in a highly viscous environment (low reynolds number).
How will I get data from my simulation for V versus r as in figure -1?
Thanks again
Old   February 10, 2010, 09:40
michael barkhudarov
Thanks again
You can just plot say y-velocity component as a function of x using the 1-D plotting tool in the GUI.
Old   February 19, 2010, 08:41
s Kumar
Is there anyway to measure the force produced by a GMO object in flow3D?
Thanks
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 13:00
flow around a cylinder pXYZ Main CFD Forum 14 July 25, 2011 10:05
Rotating cylinder with liquid propbala03 FLOW-3D 1 September 30, 2009 23:52
Spinning Cylinder Luiz Eduardo Bittencourt Sampaio Main CFD Forum 8 June 10, 2001 00:45
emptying liquid from spinning circular tube uvce Main CFD Forum 0 July 2, 1999 10:26
