Home > Forums > Software User Forums > FLOW-3D
Two-phase Flows and Turbulence Models
Old   September 6, 2010, 05:28
Question Two-phase Flows and Turbulence Models
Bcan is on a distinguished road
I am tring to model a two-phase flow which gas is turbulent and the liquid is laminar. However fluid tends to breakup instead of forming a film when the turbulence model is activated.
Is there a way to activate turbulence for one of the fluids and not for the other?
Thanks for your help
Bcan is offline   Reply With Quote
Old   September 10, 2010, 21:49
michael barkhudarov
MuxaB is on a distinguished road
I am afraid there is no way to do it. I suggest turning turbulence off all together to maintain a stable interface
MuxaB is offline   Reply With Quote
Old   September 11, 2010, 07:28
Post
Hello MuxaB,
Thank you for your reply.. I have tried that.. it gives me a stable interface however the velocity profiles, pressure distribution and shear rate between fluids are completely off compared to experimental results.. And the problem is we are intrested for both of these profiles...
I can get more reasonable profile modifying the turbulence mixing length.. Do you think it would be possible to define turbulence for only one fluid writing a user input file?
It is quite disappointing that we have to define turbulence model for both fluids..
Thanks..
Old   September 11, 2010, 12:28
michael barkhudarov
You'd have to modify the code for it, which is possible if you have Intel 9.1 FORTRAN compiler. For example, you can go into the function MUCAL where fluid viscosity is computed and reset it to the molecular value in the liquid.
Alternatively, you could change the subroutine QSADD to reset turbulent energy and dissipation, TKE and DTKE to the default levels.
Old   September 11, 2010, 14:25
I have Intel 9.1 FORTRAN but I haven't really used FORTRAN except writing very simple user input file to ABAQUS couple of years ago, but I will look into those options. Thank you..
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
Multiphase Turbulence: K-E per phase meangreen FLUENT 0 August 20, 2009 18:34
Why Turbulence models are not universal. Senthil Main CFD Forum 4 July 5, 2000 04:34
turbulence models for strongly separated flows peter schaffarczyk Main CFD Forum 3 February 9, 1999 17:49
