Home > Forums > Software User Forums > FLOW-3D
Beginner Problem
Old   November 4, 2010, 14:58
Default Beginner Problem
Sly787 is on a distinguished road
Hi All,
I'm italian and I'm an engineer who works in inkjet world. I'm developing a new piezoelectric printhead for printing on tiles and I need to simulate drop formation.
When I had to simulate pressure history and velocity history I used FLUENT and I model a 2d surface, so with axis-symmetry condition I can obtain a full developed structure.
For drop formation I think Flow-3d is better than FLUENT, so I'm trying to use it, but can I work in the same way?
Can I model a 2D surface for 1/2nozzle and use symmetry to have other 1/2? Or in general is possible to simulate 2D or 1D problem?
Because now I model 2D surface, but when I mesh it software crashes if try to use a 2D mesh. When a 3D mesh all is ok, but I want a 2D problem.
Thank You.
Sly787 is offline   Reply With Quote
Old   November 4, 2010, 22:57
michael barkhudarov
MuxaB is on a distinguished road
yes, you should be able to run 1d and 2d problems and use symmetry in FLOW-3D. There are several examples of such modeling in the Examples directory in the installation.
What is the error message when it crashes?
MuxaB is offline   Reply With Quote
Old   November 5, 2010, 02:55
Nothing message.
Simply Win7 crashes and exits from program.
Old   November 6, 2010, 19:40
michael barkhudarov
Originally Posted by Sly787 View Post
Nothing message.
Have you talked to support? At what stage is it crashing, during pre-processing or some way into the simulation?
Old   November 7, 2010, 04:37
It crashes after meshing when I begin to set-up boundary conditions. When I open boundary conditions window after model geometry and mesh.
I can't set any boundary conditions.
Old   November 7, 2010, 12:03
michael barkhudarov
Oh, so the GUI crashes as soon as you start setting up the boundary conditions, right? I have not heard of this problem. Have you reported it to support? Can you attach here the prepin file?
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Incoherent problem table in hollow-fiber spinning Gianni FLUENT 0 April 5, 2008 10:33
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
problem with using colocated code Jack Main CFD Forum 0 December 15, 2002 00:15
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
